name the valve...
Old Nov 15, 2007 | 05:13 PM
twkdCD595's Avatar
Default name the valve and its purpose...
whos up for trivia... let play, name this valve and more importantly... its purpose.... #5 in the diagram.
Old Nov 15, 2007 | 05:28 PM
twkdCD595's Avatar
Default Re: name the valve and its purpose... (twkdCD595)
ok the suspense is killing me, ... its a Fuel injection air (FIA) control solenoid valve.
but the hell does this little turd do? I am elimating things I dont need and it is looking like it wants to find a home in my trash can... but I figured it would be good to know what it does first. I know, right... picky aint I.
Old Nov 15, 2007 | 09:49 PM
bseriescrxsi's Avatar
do one of the lines on it run down to the rear motor mount?
Old Nov 16, 2007 | 04:04 AM
twkdCD595's Avatar
Default Re: name the valve and its purpose... (bseriescrxsi)
nope.
ok so agian the suspense is killing me. between 1300 and 4500 rpms a ground signal is applied to this FIA control solenoid valve... which then bypasses additional air into the motor through a tract in the intake manifold flange, right around each injector bung.
stupid... going to be removed since I have hondata and tune adjusted to compensate. we shall see if I get a check engine for it, if so I would asume I can just jumper the harness to get rid of that.
anyone else deal with one of these yet? is there a code for this useless piece of ????
Old Nov 16, 2007 | 10:52 AM
oem_certified_accord's Avatar
dont throw it away twkd, box it up just "in case"
Old Nov 16, 2007 | 11:20 AM
pos_cd5's Avatar
Default Re: name the valve and its purpose... (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord &raquo;</TD></TR><TR><TD CLASS="quote">dont throw it away twkd, box it up just "in case"</TD></TR></TABLE>
packratting FTW!...well, not really, its a rather annoying habit. but god knows the moment you throw it away your going to need it.
F20Cdriver
Feb 21, 2015 07:55 PM
KidFrost
Feb 16, 2008 05:08 PM
Monkey Fing a Coconut
Oct 10, 2004 12:45 AM
Ri5e
Aug 13, 2002 07:35 AM
