obd0 to obd1 distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hatcher »</TD></TR><TR><TD CLASS="quote">here you go with your swap...good luck.
the large white wire that is for ICM which side of the harness should I find it on? Im in the middle of a crisis please help the crx the motor came out of had the white coming from the driver side but the crx its going into doesnt have a white wire on that side all the other wires match up except that one. redoing someone elses conversion sucks
Modified by turbob18si at 6:21 PM 11/15/2007
</TD></TR></TABLE>the large white wire that is for ICM which side of the harness should I find it on? Im in the middle of a crisis please help the crx the motor came out of had the white coming from the driver side but the crx its going into doesnt have a white wire on that side all the other wires match up except that one. redoing someone elses conversion sucks
Don't cut any wires!! just de-pin the OBD 0 plug and Re-pin them into the OBD 1 plug like I did, looks OEM and no cut wires!
This is my OBD 0 CRX Si harness that I am fitting onto the D16 z6 I am putting in it, looks OE at the plug anyway, gotta finish everything else obviously.
Guest
Posts: n/a
Not tryin to thread jack here...but uh if you de-pin the obd0 distributor plugs and put them in obd1 plugs to hook up to a obd1 distributor wouldn't it work the same or do you HAVE to have a obd1 ecu and jumper also to use that obd1 distributor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Contender25 »</TD></TR><TR><TD CLASS="quote">So i Am gonna need a obd1 ecu if i re-pin my distributor plugs on my obd0 harness to use my obd1 gsr distributor, correct?.
Yes. The pickup signal is different or something. Can't remember exactly but I know they are not compatible.
</TD></TR></TABLE>Yes. The pickup signal is different or something. Can't remember exactly but I know they are not compatible.
88ED8
13
Jan 10, 2005 04:21 PM
