Can someone tell me what the circled part is and where to hook it up for a JRSC sohc THANX!!!
Old Nov 15, 2007 | 03:24 PM
Budget Racer's Avatar
Default Can someone tell me what the circled part is and where to hook it up for a JRSC sohc THANX!!!
What is it, where does it go?
Help!!!
Old Nov 15, 2007 | 05:56 PM
EFbomb's Avatar
thats the eject button
be kind, rewind
Old Nov 15, 2007 | 06:10 PM
non-VTEC's Avatar
Default Re: Can someone tell me what the circled part is and where to hook it up for a JRSC sohc THANX!!! (B
im pretty sure you are supposed to connect that thing to the relay.......i think it was a black wire........double check the JR instuctions.
Old Nov 15, 2007 | 06:50 PM
garrett818's Avatar
that is the boost pressure sensor. It gets plugged into the fuel enrichment relay.
Old Nov 16, 2007 | 04:41 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrett818 &raquo;</TD></TR><TR><TD CLASS="quote">that is the boost pressure sensor. It gets plugged into the fuel enrichment relay. </TD></TR></TABLE>
Old Nov 16, 2007 | 08:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrett818 &raquo;</TD></TR><TR><TD CLASS="quote">that is the boost pressure sensor. It gets plugged into the fuel enrichment relay. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah thats what I thought, but where is the fuel enrichment relay? Is that a part of the JRSC kit as well.
Sorry I bought it used so I'm not sure.
By the way I'm not using the FMU. I'm using an OBD1 P28 chipped ECU, with RC-440's, and pressure regulator.
so far the swap runs like crap!!!!
Old Nov 16, 2007 | 09:12 AM
rmcdaniels's Avatar
You don't need the sensor/relay if you are using a chipped ECU and 440's, you need tuning.
Old Nov 16, 2007 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">You don't need the sensor/relay if you are using a chipped ECU and 440's, you need tuning.</TD></TR></TABLE>
Ah Thanx!!!
I've seen you around, your the JRSC resident expert. I trust your opinion, and will have a question or two, if you don't mind a Pm.
Old Nov 16, 2007 | 09:58 AM
WEIRD IT POSTED TWICE!
EDITED
Modified by Budget Racer at 12:18 PM 11/16/2007
Old Nov 16, 2007 | 06:33 PM
rmcdaniels's Avatar
PM me any time if you have a question, although I've never done a D-series, so I don't know how much help I can offer.
Old Nov 16, 2007 | 09:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">PM me any time if you have a question, although I've never done a D-series, so I don't know how much help I can offer.</TD></TR></TABLE>
Thanx!!
PM'd : Need info on alternator relocation bracket for sohc JRSC.
BigJ5
Apr 19, 2008 08:06 PM
slo bus
Oct 31, 2004 08:43 AM
Turbo'dMex-A-Keen
Sep 23, 2004 09:24 AM
nicklk
May 27, 2004 07:29 PM
DC2_TEG
Mar 3, 2004 06:59 PM
