is 223 whp about right for a JRSC lude?
untuned, no, tuned yes.
Unless he got lucky and just had some good settings to begine with.
[Modified by el_Presidente, 10:15 PM 6/24/2002]
so you're saying that's right if it's tuned??? well it's not tuned, so it's not right??? i'm wonderin when i do get my car tuned, where it'll be. i'm shootin for the 230's. i need to get a new exhaust (larger piping) and replace my field's vtec-afc with the apexi vafc. i just put in new ngk iridium plugs. you think 230's is possible after all this and a dyno tune?
I think it's possible.
with an intake an exhaust-
hard to read, but it is 222 and 187 with headers, intake, exhaust,
ignition, clutch, flywheel and pulleys
[Modified by sloaccord, 1:39 AM 6/26/2002]
thanks. can you explain that dip in power right before the vtec crossover point? mine has the same thing, but much more drastic of a dip than yours. thanks.
SloAccord: What's with the top dyno? It must have a V-AFC or something cause there is no lag/dip before VTEC ?
tuning! it doesnt have a vafc; it's all about proper tuning. I cannot vouch for the bottom dyno, but the top one is dynoed by my friend, vaportrail (he's mostly in the FI forum). i have no doubt it's his skills that straightened out the curve.
220hp untuned is possible with bolt ons and fuel pressure set to ~70psi and timing around 3 clicks from min. It is exaclty where most Preludes are with that setting. With tuning mid 230's is possible.
elpiar
Jun 7, 2006 01:00 PM
