$800 Carbon Fiber hood problems. [From Password]
Old Nov 15, 2007 | 01:02 PM
RockinthEFhatch's Avatar
Default $800 Carbon Fiber hood problems. [From Password]
So naturally after 4/5 hours of fitting my hood perfectly; I open it up and sure enough the PasswordJDM hood damper ******* rips the god damn hood hinge right off the hood. Now the tapped sleeve is all smooth and I don't know what the expletive to do . I called them up and talked to Leo who has helped me in the past. He said "that sucks" and that got me all steamed. I mean I don't expect a new hood out of it but I was hoping they could at least steer me in the correct direction. Well here's a couple pictures of the damage. (Keep in mind I have yet to even drive my car since the restore)
PasswordJDM parts =
Old Nov 15, 2007 | 01:04 PM
Default Re: $800 Carbon Fiber hood problems. [From Password] (RockinthEFhatch)
Oh and my question is what do I do? haha Should I attempt to retap the sleeve?
Old Nov 15, 2007 | 01:06 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Holy **** does that suck
I never trusted those things, my OEM prop works fine on my VIS cf zc hood.
Soory to hear that.
I am not sure you can even re tap that sorry to hear that happened someone with some CF knowalge might be able to help better.
Old Nov 15, 2007 | 01:11 PM
Tippyman's Avatar
Default Re: $800 Carbon Fiber hood problems. [From Password] (***$nyper)
You'd probably have to mold over it and re-tap.
But to be honest I'd probably not try to re-use them.
Old Nov 15, 2007 | 01:12 PM
loudandlow's Avatar
Damn!!! i'd be pissed to... "that sucks".. YEAH IT DOES *******!!! hahaha man
now we all know not to use dampers with cf hoods, especially the password combo!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">Oh and my question is what do I do? haha Should I attempt to retap the sleeve?</TD></TR></TABLE>
That seems to be your only option, if you have enough meat to tap it is another question....
Old Nov 15, 2007 | 01:13 PM
Default Re: $800 Carbon Fiber hood problems. [From Password] (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">You'd probably have to mold over it and re-tap.
But to be honest I'd probably not try to re-use them.</TD></TR></TABLE>
Re-use the sleeves? or the dampers? I'm not planning on using the dampers again.
Old Nov 15, 2007 | 01:14 PM
Default Re: $800 Carbon Fiber hood problems. [From Password] (loudandlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudandlow &raquo;</TD></TR><TR><TD CLASS="quote">Damn!!! i'd be pissed to... "that sucks".. YEAH IT DOES *******!!! hahaha man</TD></TR></TABLE>
Yeah I said "No ****."
Old Nov 15, 2007 | 01:15 PM
sloweredcivic's Avatar
i would try to re tap the hood with these things forget what they are called but its basically a short tube with threads on the outside and inside so you can drill the whole bigger and tap it for the tube then use a bolt the inside diameter, i would use some expoxy like 3m 8115 glue if you have access to any of there products like through a body shop, when you screw the tube into the hole.
Old Nov 15, 2007 | 01:16 PM
Default Re: (sloweredcivic)
I'm not gluing my hood... I'm a rich white male haha
Old Nov 15, 2007 | 01:18 PM
Maxcapacity's Avatar
Try using that liquid alluminun stuff and fill it, bore it , tap it. Would it be even possible just to tap it to the next size up?
Tippyman's Avatar
Default Re: (RockinthEFhatch)
A carbon fiber hood is basically made out of glue.
Old Nov 15, 2007 | 01:23 PM
Ermil's Avatar
Default Re: (Tippyman)
Did you call or email them?
Old Nov 15, 2007 | 01:26 PM
Solid Motorsports's Avatar
Honda-Tuning's install of the Tein hood dampers had instructions to relieve some of the gas pressure if you're using the damper with a carbon fiber hood, since the pressure is set up for the weight of the stock hood. Could this be the cause? Did PasswordJDM's come with any instructions? If it broke when you lifted the hood from its down position, it would seem like the pressure was too high for the weight & strength of the hood. In either case, they should hook you up with a solution.
For aluminum, you use helicoils to make tapped threaded holes. There may be a way to make something like this work.
Old Nov 15, 2007 | 03:13 PM
Crx Jimmy's Avatar
Default Re: (Solid Motorsports)
I would just use the next size larger bolt and re-tap. I think the next larger size up from 6mm is probably standard thread try a 1/4" tap
Old Nov 15, 2007 | 03:23 PM
Default Re: (Crx Jimmy)
Thanks guys I'm going to call them and try to get a metal hood. My paint is fresh and I could just get the hood matched perfectly and not have to worry about it. I'll try tapping the thread's tomorrow and show you how it goes though.
Old Nov 15, 2007 | 03:37 PM
Fuzzy Rhubarb's Avatar
I'd be really pissed off... I always thought the password dampers are supposed to be for cf hoods. Whether or not you have a warranty, you should bug the hell out of them until you get another hood.
Old Nov 15, 2007 | 03:48 PM
Default Re: (Fuzzy Rhubarb)
Yeah and the pressure was released and the man walked me through it on the phone. I'm sure they'll take care of it - otherwise there'll be hell to pay
Old Nov 15, 2007 | 03:53 PM
DADADAAAMN's Avatar
wtf. i would go go his store and just punch him in the face. then i'd ask him if that sucked!
RCautoworks's Avatar
Don't try to tap it until you talk to them, some people won't warranty anything once work has been done, or tried to be done.
Seems like more people are having issues with them
https://honda-tech.com/zerothread?id=2097794
Old Nov 15, 2007 | 04:02 PM
SIred91's Avatar
Rainman
Default Re: (RCautoworks)
*will never use dampers on a civic hood anyway*
No matter the bling factor........
Old Nov 15, 2007 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Don't try to tap it until you talk to them, some people won't warranty anything once work has been done, or tried to be done.
So I just got through sending them two emails: 1) showing my broken parts and asking for replacements 2) I gave them the above listed link so that they can see I'm not the only one.
I'm sure they'll back their product up though. They know of my restoration and actually care about my business.
Old Nov 15, 2007 | 06:47 PM
1989CivicSi's Avatar
I'm sure they'll back their product up though. They know of my restoration and actually care about my business. </TD></TR></TABLE>
^ That's the way to do it . Don't even attempt to fix the hood until then otherwise you may be out of luck for a replacement if they do intend to give you one. If they flat out screw you over, bash on Password:JDM like everyone else and helicoil or fill in the hole/re-drill it .
Old Nov 15, 2007 | 09:48 PM
Default Re: (1989CivicSi)
Is there anyone on Honda-Tech who works for password?
Old Nov 16, 2007 | 04:48 AM
WhiteboyATL's Avatar
owch. i would have been pissed off if someone would have told me "that sucks"
Old Nov 16, 2007 | 05:03 AM
IT GUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">Is there anyone on Honda-Tech who works for password?</TD></TR></TABLE>
yup, this guy https://honda-tech.com/zero...23164
they're sponsers, so they should be on regularly
sorry about the hood/dampers man, hope it gets handled
