oil changes
Hey people,
Just wondering if anyone else has run into this situation... I did an oil change at my last service interval and found that only about 2 out of 4 litres of oil drained out of the pan. I thought nothing of it because I know that certain driving styles causes oil consumption. I just recently did another oil change and found that the same amount drained out of the pan this time as well, but I didn't drive the car nearly as hard as the last 5000kms. Is this normal?
...or you have a ghost.
Unless you have buildup of sludge equivelent to 2 qts of oil every change. So now you have about 4 qts. of sludge.
....though thats just a theory <-----
hehehehe...i really dont know tho.
There are no leaks anywhere, I've looked all around. I know only 2 are coming out because I buy 4x 1litre bottles to do the fill and refill them whith the old oil when I drain it. I had brought my car into Honda to fix a blown head gasket and this started happening after they changed it. Possibility they did something wrong? I don't normally check the dipstick because everything was fine until now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iGGY366 »</TD></TR><TR><TD CLASS="quote">There are no leaks anywhere, I've looked all around. I know only 2 are coming out because I buy 4x 1litre bottles to do the fill and refill them whith the old oil when I drain it. I had brought my car into Honda to fix a blown head gasket and this started happening after they changed it. Possibility they did something wrong? I don't normally check the dipstick because everything was fine until now.</TD></TR></TABLE>
shouldnt be the dealerships fault, when u got your hg replaced you completely strengthened the head of your motor. The bottom end is still weak and needs a rebuild. Honda actually recommends getting the bottom end rebuilt after a headgasket but nobody does it because thats pricey ish.
pjr710
Feb 6, 2009 10:23 AM
