Lighting HID/Xenon kits, Retrofits and Associated Topics
what are these things on the hid bulbs?
Old Nov 15, 2007 | 12:13 PM
androO's Avatar
Default what are these things on the hid bulbs?
theres this metal sheild that i havent seen before. what is its purpose?
Old Nov 15, 2007 | 12:32 PM
B20inDCinLBC's Avatar
thats pretty much used to cover light from shooting up to blind ppl.. It's a shield.
Old Nov 15, 2007 | 12:38 PM
It actually looks ghetto.. For cars that come with HID kits but no projectors, they use the D2R bulb. It has a shield on the bulb to prevent light from blinding others. And with cars that has projectors, inside the projector, there's a cutoff shield that does the same thing. So the bulb does not need a reflector shield on it. And that bulb is the D2S bulb..look
Left- D2R with the shield
Right- D2s w/ no shield
Old Nov 15, 2007 | 01:19 PM
androO's Avatar
ok because i was browsing the web and found these things and i was like eRrrR what the heck are these things.
so its a shield from stopping someone to go blind eh?
Old Nov 15, 2007 | 02:05 PM
denshu's Avatar
Default Re: (androO)
Those shields are mostly for plug and play applications to not light up the bottom half of the reflector housing so it doesn't blind people.
Still blinding though, if you have a plug and play kit.
Old Nov 15, 2007 | 04:53 PM
CarbonizedDX's Avatar
Default Re: (B20inDCinLBC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20inDCinLBC &raquo;</TD></TR><TR><TD CLASS="quote">It actually looks ghetto.. </TD></TR></TABLE>
Ever looked head on into reflective hid housings? The clear units you will be able to see the internal shield that covers most of the bulb (or you'll see a darker less reflective reflection in the lower half of the housing).... A shield is a shield, weather it's ceramic on the bulb or metal outside the bulb.
And to be clear, those exterior metal shields on the bulb are ONLY used on plug n play kits. Even Casper shields are for installing HID into an H4 application in a plug n play fashion.
If you are using H4 and want to do pnp, please get the bulbs with the shields and those units will be better due to the full covered tip..
Old Nov 16, 2007 | 04:18 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
those look like some kind of hi/low kit w/ solenoids to change the focal point of the bulbs.
Old Nov 16, 2007 | 05:13 AM
devani's Avatar
Default Re: what are these things on the hid bulbs? (androO)
those are H4 application....bi-xenon either shield or the bulb moves to engage high beam... solenoid inside made in china
EM2_Kid
Lighting
12
Jun 15, 2008 05:20 AM
boidc24dr
Lighting
Jan 14, 2008 10:37 PM
slamed93si
Nov 7, 2003 02:56 PM
aburn
Jan 25, 2003 09:59 AM
