mpfi help??
this has already been coverd prob but im doin the mpfi swap now and was wondering if i had to get the si fuel line comin from the fuel filter? will my dx line work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by innes887 »</TD></TR><TR><TD CLASS="quote">this has already been coverd prob but im doin the mpfi swap now and was wondering if i had to get the si fuel line comin from the fuel filter? will my dx line work?</TD></TR></TABLE>
The DX line will work okay, but you absolutely have to have that little plastic and metal thing that goes on the end of the Si fuel rail. I forget the name of it, but it was something weird.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex »</TD></TR><TR><TD CLASS="quote">I forget the name of it, but it was something weird. </TD></TR></TABLE>
Fuel pipe insulator, its about a $1 at the dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9Si-T »</TD></TR><TR><TD CLASS="quote">
Fuel pipe insulator, its about a $1 at the dealer.</TD></TR></TABLE>
Coulda sworn the metal piece that's like 24mm was more than that?
Goes to show what I know
ok well i got it to fit thanks guys, but i have another question haha. for the coolant lines goin to the iacv, where do i route them. and also am i supposed to T off the vacuum source goin into the manifold for the map sensor and the purge solenoid
ok i just started it and it runs like crap. im gettn a code 8 which is tdc position, what would cause that? and also im gettn a code 16 which is injectors. i can smell straight gas coming out ot the exhaust so i think the injectors might be staying open. where should i start and check these problems?
yeah i did. i just took everything out and rewired it back to dpfi
so now i can say i had mpfi for a little haha. the dizzy i bought from some ******* on honda tech sold me a bad one so now i have to get another one. hey ef9si-t, whats that other sensor on the back of the mani that i got from you? its by the idle air controle valve. cus i couldnt find the connector in my engine bay for it
FalkenSiR
Feb 16, 2005 09:22 PM
