PLease help: Banging noise from front left of car only in sub 32 degree temps
Hi all,
I've been stumped with diagnosing a problem with my 97 base model MT prelude.
WHen the temperatures fall below freezing, whenever i start off in 1st gear as soon as my wheels start moving there is a clanging/banging/popping/clicking noise from the front left of my car. hard to describe the sound almost like a CV joint.
i've inspected all the radius rod, LCA, tie rod, UCA... everything is properly torqued and no signs of damage or wear. i convinced myself it was the lower ball joint and changed it. problem still there. i emphasise that this only occurs during sub freezing temperatures. inner and outer CV boots are in excellent shape with no cracks or tears.
any clues as to what it might be? i'm selling my car soon and would like it to be in tip top shape for the future owner.
car has ~125k miles if that helps narrow down suspected causes.
thanks for the help h-t!!
yes from the front driver side which is the left side LOL.
the sound is a series of 2 or 3 clicks/bangs as i begin in 1st gear. always when i'm just moving from a stop. once i'm driving i dont hear the soudn any longer.
it definately sounds metal on metal which led me to belive ball joint which is why i changed the lower one but that did nothing. theere does not seem to be any play in the upper ball joint or in the tie rod. steering is tight no problems there.
i'm baffled!
i'm baffled!
MolecularIntegra
Jul 11, 2017 08:34 PM
picthis1
Feb 1, 2012 08:32 PM
