dose this look right?
Old Nov 14, 2007 | 09:25 PM
thenewguy93eg's Avatar
Default dose this look right?
my car jumps up and down when i take off i think its a this motor mount but cant tell
Old Nov 14, 2007 | 09:31 PM
.:Swig:.'s Avatar
Default Re: dose this look right? (thenewguy93eg)
driver side motor mount doesnt look bad.... any better pics?
are you running hydraulics?
Old Nov 14, 2007 | 09:39 PM
Default Re: dose this look right? (.:Swig:.)
o hay i hit the switchs all day long
its a trip it just bumps up and down it has a new clutch and trans (jdm trans) when i try to drive slow it happens but when i take off fast its fine
well not that much better lol
Old Nov 14, 2007 | 11:33 PM
MR.johnson's Avatar
what type of clutch?
Old Nov 15, 2007 | 12:42 AM
eg1993lpc's Avatar
Default Re: dose this look right? (MR.johnson)
oem stock from napa i dont no the brand
Old Nov 15, 2007 | 12:45 AM
Syndacate's Avatar
Default Re: dose this look right? (eg1993lpc)
Hondas tend to jump on/off power at low RPM when you need to change ur plugs, wires, dizzy rotor, and cap...but somehow I don't think that's the problem here...
Old Nov 15, 2007 | 12:50 AM
eg1993lpc's Avatar
Default Re: dose this look right? (Syndacate)
lol what do you mean not the problem here? i just had my dizzy rotor, and cap changed 2 day ago but i have had the car 3 years now and its been the way sence day one
Old Nov 15, 2007 | 01:03 AM
GSRpoweredSI's Avatar
my car does the same thing but i put a clutchmaster fx300 which is there stage 3 clutch i believe, as well as a 9lbs flywheel. i was told that it was the lightened flywheel and then i was also told it could be the motor mounts or a combo of two since the motor is trying to keep up with the lightened restrictions causing the stock mounts to take alot more stress. im in the lookout for some hasport to see if it fixes it. goodluck on your findings.
Old Nov 15, 2007 | 06:18 AM
rleonekc's Avatar
Default Re: dose this look right? (GSRpoweredSI)
Its because you have SOOOO much horsepower, your car doesn't know how to handle it.
Old Nov 15, 2007 | 11:26 AM
lpc805EG's Avatar
Default Re: dose this look right? (rleonekc)
no not relly dose any one else have this problem?
if so how did you fix it?
Old Nov 15, 2007 | 11:39 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: dose this look right? (lpc805EG)
this happened to me once after a cluch job.
check your bolts taht connect you tranny to your motor. there should be no gap between both. i had a gap the bolts were coming loose. for not having the right tools.
Old Nov 15, 2007 | 02:47 PM
ejoner's Avatar
Default Re: dose this look right? (Dead CIVIC)
Check your other motor mounts, upper mounts rarely go bad unless the the front ones tear and you don't replace them then the uppers tear also.
tallguy21
Mar 20, 2014 05:36 PM
urquidezj
Jun 25, 2007 12:27 PM
Techy
Nov 29, 2006 05:42 PM
z1 master
Apr 10, 2004 09:23 AM
01PYITR
Jun 30, 2002 02:58 PM
