Laggy and check engine light...
Old Nov 13, 2007 | 10:31 PM
jenheartsyou's Avatar
Default Laggy and check engine light...
I have a stock 92 b15 civic, and this is a really big emergency because I have a test at 730AM and my car just threw this light at 230AM...
The car just started feeling really laggy at half throttle in fourth, and all of a sudden I threw the light...the motor sounds different than normal, like maybe more ticking than usual or something louder than normal.....HELPPPPP
Can anyone tell me if this is serious or not or if I should start walking to school now???
Old Nov 13, 2007 | 10:45 PM
USDMCIVICHATCH's Avatar
Default Re: Laggy and check engine light... (jenheartsyou)
jump the two wire plug to the right of the glove box with a paper clip and count how many times the cel flashes, slow flashes and quick flashes, then tell us what it is and we'll try to help
Old Nov 13, 2007 | 11:11 PM
ive been counting for 133 short flashes...wtfffff
Old Nov 13, 2007 | 11:23 PM
well i dont know what im doing wrong but its still flashing....its been like 20 minutes of flashing...
Old Nov 13, 2007 | 11:25 PM
Frozen E's Avatar
H-T White Ops
Well, the code is going to repeat itself. So if you're up to 133, the code has probably repeated itself a good 20-30 times by now.
Check this thread
https://honda-tech.com/zerothread/1901557
Old Nov 13, 2007 | 11:28 PM
Default Re: (jenheartsyou)
it will keep flashing until you pull out the paper clip, for an example if it flashes like 4 times slow and once real fast it would be code 41
Old Nov 13, 2007 | 11:35 PM
its all the same speed flashes
idk what to do
Old Nov 13, 2007 | 11:44 PM
if it is a continuous short flash sequence it could be 1-9 correct?
Old Nov 13, 2007 | 11:46 PM
Frozen E's Avatar
H-T White Ops
Almost sounds like it might be an ECU problem.
Got a digi cam with video? Do a 30 second video of it and post it. If you need hosting, shoot it to me in an email. here
Old Nov 13, 2007 | 11:58 PM
Default Re: (IslandSi)
i guess i'll just try to make it to school and have someone look at it tomorrow...
hope its nothing too bad, thanks for your help guys
Old Nov 14, 2007 | 05:38 PM
Frozen E's Avatar
H-T White Ops
So, did you take the car to Checker or Autozone and get them to scan it for you?
What came of it?
DuVaL rAcEr
Jan 27, 2007 06:23 AM
JDM-EJ1
Apr 5, 2005 11:55 AM
thenglishman
Aug 24, 2004 08:50 AM
99IntegraGS
May 3, 2004 07:18 AM
wadafa
11
Oct 3, 2002 03:49 PM
