Finally my car is running right!!! Woohoo!
Will you make something up for me please?
I'd just like to say thanks for all the help here on HT. For the injector issues, boost controller help, etc.
After being under the car, I finally got my exhaust leak fixed. It was a major one....the turbine housing was separated from the downpipe about half an inch! That thing was loud.
After I fixed that, the car spools so much faster and is so much quieter. It blows off even driving normally in all gears.
Unfortunately, now that I'm actually boosting, my EGT's are much higher in normal driving. At 80mph in 5th gear, it's at about 1420F. How's that? When I start to boost, it drops to 1400F and stays for about 3 seconds before rising easily past 1500F. Then I let off.
That's only at 8psi as well. When the BC is set at 12psi, the temp climbs instantly. Would an MSD BTM solve this? And no, I'm not getting a standalone.
Wow, you're car's running right ! What's that feel like ??? heh heh
Are you on stock distr. timing ? Try setting the BTM to a full 1 degree per psi to 8. 1.25 if you go to 12 psi
[Modified by X2BOARD, 2:22 PM 6/24/2002]
man 1500 degrees that is hot. i dont think it is suposta get that hot. what was it like before the turbo? and where do you have the probe installed?
Hehe....yup, it's finally running right. Well, I dunno about "boosting right" but it's real smooth right now with no bogging or hesitation.
I don't have the BTM right now so it's stuck on stock timing right now. I spoke to several people (pro tuners and regulars) and they say that even 1600F is fine if you're tuned correctly. You just can't stay there forever. I haven't taken it that high just yet though.
Who said gettin out of the darkside??? Not I.
And Etown? Yeah rite...not for a while since I'm so broke. Soon enough guys....soon enough.
I never go above 1350.
My setup is stock b18b teg with dragIII.
Wow, I like your temps. I'm running a stock FPR, S-AFC, and 440's. It's a trick that my tuner uses all the time. It nets him great times and reliable motors, but I just get so worried because all the honda-tech'ers are running much lower temps.
I have forged pistons and rods, a JE blockguard, stock sleeves bored to 81.5mm. The crank is cut, polished, and balanced. The head has Crower 402T cams with the corresponding valve springs/retainers.
kinda ot, but what egt gauges and probes are you using, I'm getting one soon.
What do you think about the autometer street egt kit?
I'm using the Westech EGT guage and probe. If you are into looks, then this one is not for you, however, if you are going for function then it's rather good.
http://www.hwy29.com/catalog.htm
Autometer EGT is pretty good for the price, but Greddy, Apex, HKS are much better but highly priced.
Where is your probe located? Temperature readings will vary depending on the location of the probe. I don't know how much it will vary by, but I am pretty sure it won't be significant. I am using the Autometer competition probe (5244) and I just have to assume it's pretty accurate. It's at least consistent, showing 1200 degrees cruising at 75mph.
My probe is right at the manifold basically where all the runners collect on the Drag manifold.
My timing is set to slightly retarded, but I haven't checked yet. Hehe. I'll make sure I check that.
My probe is 2 inches away from the exhaust port, before the turbo on runner 3;
DragIII manifold. I've compared runner's 3 and 4 (same location--2" away from exh. port) and the readings were the same.
I've also hooked up my friends Greddy EGT guage/probe to compare readings with my guage/probe and the readings were the same. The greddy responds a tad faster though.
LUDE_4_LIFE
Sep 10, 2010 11:18 AM
vtak2nr
May 31, 2007 12:07 PM
_Shadow_
Apr 30, 2003 07:28 AM
