Need help..on type R..
Old Nov 13, 2007 | 07:16 PM
exotic_type's Avatar
Default Need help..on type R..
did any ever did a b18c type r swap onto a 96 ek hatch?if so..what parts will u need to make it a complete swap? cause from what i herd. axles will need to be removed.but im not quite sure on what size axles i will need. also the mounts..i dont know what mounts i will need.and anything else?if so can anyone just guide me and tell me what i will need..i really appreciate help.and it will be useful..if u tell me what i will need..
Old Nov 13, 2007 | 08:36 PM
JMsports's Avatar
Default Re: Need help..on type R.. (exotic_type)
what model is your EK? What OBD version Type R do you have? Its not to hard to throw a B Series in a EK chassis. That chassis also came with a B series (SI model) so its not to hard or something you cant do in your own garage. I just finished a B16A (95 DelSol) swap into a 98 EX 4door. Everything from the DelSol was used: Axles, Engine Harness (Injector Clips & Other plugs), ecu, & shifter linkage. As for the mounts, I think the only issue will be the tranny mount unless you use that of an 99-00 SI model.
Old Nov 14, 2007 | 12:15 AM
mtber's Avatar
hondaswap.com and the hybrid section of this forum will help you find every answer.
Old Nov 15, 2007 | 04:25 AM
B16B_coupe's Avatar
HRD PKR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotic_type &raquo;</TD></TR><TR><TD CLASS="quote">did any ever did a b18c type r swap onto a 96 ek hatch?if so..what parts will u need to make it a complete swap? cause from what i herd. axles will need to be removed.but im not quite sure on what size axles i will need. also the mounts..i dont know what mounts i will need.and anything else?if so can anyone just guide me and tell me what i will need..i really appreciate help.and it will be useful..if u tell me what i will need..</TD></TR></TABLE>
first of all you need to learn how to type.....
second, you need b series hydro axles
99-00 si rear mount bracket
b series front tq. mounts
use a ex harness
third you could google search this and come up with your awnser.. http://www.hondaswap.com
ps: since iam bored at work here https://honda-tech.com/zero...age=1
chuck7
Feb 17, 2009 02:32 PM
exotic_type
Nov 13, 2007 07:25 PM
silenttones
May 8, 2006 05:50 PM
Dominicanstylz02
May 7, 2006 04:01 PM
Collateral
Jan 24, 2005 07:42 PM
