FAILED emissions... (need help....)
Old Nov 13, 2007 | 02:03 PM
LNC's Avatar
LNC
Default FAILED emissions... (need help....)
Hi, I went in for my WI emission test and failed.
HC 2.74 & the limit was .800
CO 15.24 limit was 15.00
NOx as 2.40 limit 2.00.
It has a idle issuse when it warms up as well... Idle jumps and is super high... I dont hear any vaccum leaks... What could be the issuse? IAC, EGR, O2 sensor (witch is brand new!)
Let me know ...
Thanks
Old Nov 13, 2007 | 03:05 PM
turkishEF's Avatar
Default Re: FAILED emissions... (LNC)
Sorry i don't have any answers for you, but you levels don't seem too bad.
I'm sure with someones advice on here, you should be able to get it down to acceptable levels.
GL!
Old Nov 13, 2007 | 03:31 PM
RockinthEFhatch's Avatar
Default Re: FAILED emissions... (turkishEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turkishEF &raquo;</TD></TR><TR><TD CLASS="quote">Sorry i don't have any answers for you, but you levels don't seem too bad.
GL!
WTF was the point of that?
I know in IL cars before '96 are exempt. You simply need to re register your license plates. If you can't I would try throwing on a different throttle body and see what happens.
Old Nov 13, 2007 | 05:35 PM
LNC's Avatar
LNC
Well I dont want to reregister the car... that is at least another $120.00 and the car woud still have an idle issuse.... Im sure if I fix the idle it will pass...
Old Nov 13, 2007 | 05:39 PM
Try adjusting the FITV or IACV
Old Nov 13, 2007 | 05:55 PM
LNC's Avatar
LNC
Default Re: FAILED emissions... (RockinthEFhatch)
how?
Old Nov 13, 2007 | 05:57 PM
JustAnotherRex's Avatar
Wiggle the knuteson nut until it's loose.
Old Nov 13, 2007 | 06:11 PM
LNC's Avatar
LNC
What causes the Hydrocarbons to run high?
Old Nov 13, 2007 | 07:09 PM
LNC's Avatar
LNC
ITs running rich... has a high idle... how do I fix it?
Old Nov 14, 2007 | 10:59 AM
LNC's Avatar
LNC
there are no coads...
Old Nov 14, 2007 | 12:13 PM
thesmogman's Avatar
Yes, it is running rich. You have poor combustion = CO and you have Nox which is combustion temps that are higher than 2500 degrees.
Your idle is high. You need to check into this more. IACV cleaning? vacuum leak?
If a vacuum leak, it will raise your HC's because the ECU is thinking it is lean and trying to compensate. Also if Vacuum leak is related to just one or two cyl, You might be having misfires which will raise HC and CO.
Lastly is Nox which you should not have being that your HC's are way up.
Things to check...
Vacuum leak
Exhaust leak
IACV cleaning
Timing and or tune-up.
Valve adj?
You mentioned EGR? does your car have one?
Old Nov 14, 2007 | 06:59 PM
LNC's Avatar
LNC
Default Re: FAILED emissions... (thesmogman)
I pulled off the iacv and cleaned it with the last bit of carb clean... the idle was good last night but when I drove it today the idle was high again... it didnt seem as high as when I took it to emissions... Seems the motor is blow some smoke too (only when you get on it...)
Old Nov 14, 2007 | 07:04 PM
Janos Lin's Avatar
Did they measure CO2 and O2 levels as well?
Janos
Old Nov 14, 2007 | 07:05 PM
Default Re: FAILED emissions... (Janos Lin)
Try throwing a 6cyl Formula can of restore in there. That cures all ailments. I LOVE RESTORE and swear by it
Old Nov 15, 2007 | 07:18 PM
LNC's Avatar
LNC
I put in a 4cyl can in... I will try the 6cyl with the next oil change...
Old Nov 16, 2007 | 07:28 AM
iheartteal's Avatar
put some rubbing alcohol in the tank and retard the timing
mdrshewrote
Jul 11, 2013 09:56 PM
CentralCalLude92
Jun 24, 2008 05:48 PM
austinkli
May 11, 2008 07:37 PM
Jynxeh
Aug 9, 2007 11:56 AM
