reading rpms
reading rpms
I should probably already know this, but is there a tool i can get a hold of that will measure my rpms for me? I need to play with the idle a little and I would like to be able to read what rpms I'm at. Is there something I can buy or use to read that and if so what is it called?
H-T White Ops
I know at least some cars do have a "test tachometer connector". I'm not 100% sure what they do with that, but it might help you.
Here's some info, but keep in mind it's for a 7th gen.
http://www.tegger.com/hondafaq...e.pdf
Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">A tachometer? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fryman »</TD></TR><TR><TD CLASS="quote">Yea a tachometer tells you the rpm.</TD></TR></TABLE>
thankyou smart asses, i never knew that's what a tach is for. Actually, mine is a dx, and i haven't swapped the gauge cluster yet, so i don't have a tach. And i was curious as to wether or not there was something i could just connect up for 5 minutes or something rather than spending $80 on a gauge cluster with a tach right now.
Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">I know at least some cars do have a "test tachometer connector". I'm not 100% sure what they do with that, but it might help you.
http://www.tegger.com/hondafaq...e.pdf</TD></TR></TABLE>
i can't open that for some reason, but i have a tach that isn't part of a cluster, i'm gonna try and rig it up without pulling out the cluster, and see if i can't make something work.
H-T White Ops
If you don't have a program that reads PDFs then it won't open. It really doesn't say much besides it's a Honda document that actually mentions the test tachometer connector.
Re: (austinkli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austinkli »</TD></TR><TR><TD CLASS="quote">
thankyou smart asses, i never knew that's what a tach is for. Actually, mine is a dx, and i haven't swapped the gauge cluster yet, so i don't have a tach. And i was curious as to wether or not there was something i could just connect up for 5 minutes or something rather than spending $80 on a gauge cluster with a tach right now. </TD></TR></TABLE>
Heh wasn't being a smartass.If you want accurate shifting and some assurance that your not going to blow your engine,you will need a tach anyway so why not just buy one?
