Hondata s200 vs s300, running rich, injectors, JRSC
Old Nov 13, 2007 | 12:52 PM
Frstyl838's Avatar
Default Hondata s200 vs s300, running rich, injectors, JRSC
i've been researching this for quite sometime and can't figure out the real big differences besides the s300 is newer and it has direct usb for a laptop or whatever. is the s200 going to do the same thing im assuming?
I have 99 civic coupe si with jrsc and it feels like its running really rich. i have been told to get an ecu, maybe new, bigger, better injecotrs, and fuel pressure reg. it feels like its going to die sometimes when i start out in first as in i have to give it more gas. any suggestions would be a great help.
maybe seafoam a couple of times before an oil change to clean out injectors and the carb build up? get new injectors?
thanks ahead of time
Old Nov 13, 2007 | 01:25 PM
B18MOBBER's Avatar
Default Re: Hondata s200 vs s300, running rich, injectors, JRSC (Frstyl838)
-get the aem uego gauge and get it tuned. you'll be happy with that.
-tune goes much quicker with accurate a/f ratio
Old Nov 13, 2007 | 10:46 PM
mtber's Avatar
+2 Go have the car dyno tuned.
Old Nov 14, 2007 | 09:37 AM
Frstyl838's Avatar
1) what the hell is the AEM UEGO? is it an ECU?
2) is there anything i can do in the meantime? the closest dyno is 4-5 hrs away, and its expensive
edit: they guy I bought the car from told me to replace the 6lb pully with 9lb and it will give about 50 more hp. but im afraid to do that without rebuilding the bottom end. am i correct, or should i be fine without rebuilding? car has about 47k on original motor.
Modified by Frstyl838 at 12:55 PM 11/14/2007
Old Nov 16, 2007 | 09:01 AM
Spunkster's Avatar
Default Re: (Frstyl838)
If you are debating the s200 or the s300, the s300 is the best system to go with, especially if thre is no tuner close to you. You can make changes yourself with the s300 very easily. You should also consider getting a Wideband (I recommend the PLX).
Old Nov 16, 2007 | 10:09 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frstyl838 &raquo;</TD></TR><TR><TD CLASS="quote">1) what the hell is the AEM UEGO? is it an ECU?
Modified by Frstyl838 at 12:55 PM 11/14/2007</TD></TR></TABLE>
1. It is a wideband oxygen sensor.
Description:
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
2.The only thing you could do is buy a chipped obd1 ecu on a basemap & a wideband to drive the car on until you get it tuned. Then simply add an s100/s200 or neptune, ectune system to it later etc.
mtber's Avatar
Default Re: (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">If you are debating the s200 or the s300, the s300 is the best system to go with, especially if thre is no tuner close to you. You can make changes yourself with the s300 very easily. You should also consider getting a Wideband (I recommend the PLX).</TD></TR></TABLE>
+2
The price difference between the s200b and s300 is not very much at all.
protopro88
May 26, 2011 03:40 AM
Azcheron
May 12, 2005 07:14 AM
cleantegra
Feb 5, 2004 02:50 PM
LostLude
Sep 8, 2003 12:48 PM
92TEGsrSC
Jul 7, 2003 09:16 AM
