Zc motor swap
Old Jun 24, 2002 | 08:24 AM
blown87camaro's Avatar
Default Zc motor swap
Hey,
Im kinda new to import world..... I use my 95 honda hatchback for my daily driver and i have a blown small block 355 camaro for the street strip. BUt i found a Zc motor from jdm....its a 1.6 liter v-tech..... they say it will bolt right inot my car...is this a good motor?>? how much hp? and ive never headr of it refered to as a Zc which motor is this D16z6 ?
Thank u
Old Jun 24, 2002 | 10:54 AM
kyler's Avatar
Default Re: Zc motor swap (blown87camaro)
well its not a zc as zc's never had "vtec" and they don't drop into 92+ civics anyways....
is it dual or single cam?
got any pics?
does it say vtec on it anywhere or is this what they told you?
more info plz including the #'s off the block to the left of the exhaust mani if you'd like this motor ID'ed...
Old Jun 24, 2002 | 12:34 PM
Well i saw this motor on the JRD sight .. their selling it for 1095.99 its a sohc v-tech zC and i emailed the guy and he said it bolts right into the 92-92 honda civic..is this true???
Old Jun 24, 2002 | 10:08 PM
kyler's Avatar
Default Re: Zc motor swap (ridge racer 2)
actually they made the ZC until 2000 so finding one for the 92 hatch is not impossible.
The motor you have is from the 92-95 civic. While they do have single cam ZC motors If this code is on it then it would not be one.
explain your definition of a ZC more plz.... not bitin on ya but the only zc's i know of are:
-old brown dohc top zc's that drop in 1st gen crx/ 3rd gen civics
-blacktop doch zc for 2nd gen crx/ 4th gen civic
-and the elusive euro sohc zc for crx/ 4th gen civic....
Old Jun 24, 2002 | 10:39 PM
HEy,
WEll everyone says that... Thats what the motor title is on the ARD wed sight.. BUt it says Zc 16 motot... I did see the Zc ur talkin about for 91 crx's but this isnt that motor.. maybe they called it that i think its refered to as the D16z its a 1.6 liter sohc v-tech.....how much hp does this motor make? cuase they said itll driop right in... if so for 1095.99 thats the way im gonna go.
Old Jun 25, 2002 | 12:58 AM
kinesistech's Avatar
Lemme offer you some help.
The d16z is rated by Honda to make 125. It will bolt right into your car. If your car has a factory tachometer, its wired for vtec, if its got a factory sunroof too, its straight forward. If you have the tach only you have a vx which is a vtec engine but the o2 sensor wiring is different. If you dont have an si, youll need to add some wires and change the ECU to a p28 which is the ecu for 92-95 civic sohc vtec.
Since you said you have a blown chumaro Im assuming you just want to fix your civic. I would not pay more than 500 for that engine, unless its rebuilt, with a warranty. Thats the only way its worth 1100.
So basically it will bolt in, wiring may be and issue and it costs too much. I hope this will help you.
Old Jun 25, 2002 | 07:59 AM
Hey thanks..... Actually im just tired of listning to the ls1 4th gen camaro guys make fun of imports....Since none of them can beat my camaro i figured id build a sleeper honda that can run high 13s ... which is why i wanted the sohc v-tech.. i figure they make alot of forged internals for it.. which means once i bu it i can swap in forged rods crank and pistons and new head gaskets... change the fuel mixture and run 100 shot of spray... with 200 hp i figure i should be close to high 13s in the little hatchback. right?Oh and that motor is 1095.99 it comes form JDM with the ecu and motor.
[Modified by blown87camaro, 5:02 PM 6/25/2002]
Civic Hx-T
34
Jun 17, 2016 09:29 PM
Potential2nr
Jan 6, 2012 03:11 AM
FastAzzDA
Oct 23, 2006 07:57 AM
RexShop
12
Jan 3, 2006 10:52 PM
themex77
Jan 31, 2005 05:20 PM
