what do these pinouts do
Old Nov 13, 2007 | 08:30 AM
hatch96y7's Avatar
Default what do these pinouts do
Wwht do these pinouts do
or go to what sensor
D14-**
D4-**
A15-PCS
these are from this thread
https://honda-tech.com/zerothread?id=478377
but this thread show the pinouts diffrenthttp://technet.ff-squad.com/wiring.obd2a.htm
Old Nov 13, 2007 | 10:10 AM
hatch96y7's Avatar
Default Re: what do these pinouts do (hatch96y7)
no one
Old Nov 13, 2007 | 10:16 AM
EE_Chris's Avatar
OBD2a
D4: Ref voltage for MAP
D14: 2nd O2 input
A15: EVAP Purge control (PCS = Purge Control Solenoid)
OBD2b
D4: control "D" Indicator in cluster
D14: A/T gear position switch
A15: not used
Old Nov 13, 2007 | 10:35 AM
hatch96y7's Avatar
Default Re: what do these pinouts do (EE_Chris)
if these arent hooked up will it make ,my car run like ****
but i dont throw any code just o2 sensor and ckf
Old Nov 13, 2007 | 10:36 AM
hatch96y7's Avatar
oh its d13 not d14
Old Nov 13, 2007 | 11:02 AM
EE_Chris's Avatar
Yes, when your ECU isn't given all the sensor inputs it's looking for, the result is a less-than-smooth operating engine.
Old Nov 13, 2007 | 11:05 AM
hatch96y7's Avatar
could this be the cause of my engine acting like it isnt getting any air.
because there is a bung in my engine bay where all these wire go to i didnt trace all of them back just the mixed colored.
Old Nov 13, 2007 | 02:00 PM
hatch96y7's Avatar
+6586+45
Old Nov 14, 2007 | 01:43 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">because there is a bung in my engine bay where all these wire go to i didnt trace all of them back just the mixed colored.</TD></TR></TABLE>
I don't understand what that means.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">could this be the cause of my engine acting like it isnt getting any air.</TD></TR></TABLE>
I'd assume so. Then again, when the CEL is on, I generally FIX THAT before I start asking questions like this one.
Old Nov 14, 2007 | 06:13 AM
hatch96y7's Avatar
WELL I GOT A CEL FOR A SECONDARY O2 SENSOR AND A CKF SENSOR
65 and 54
what i meant is there is a big connector that looks like it would branch out to like two other connectors but i dont have them
Old Nov 14, 2007 | 07:21 AM
EE_Chris's Avatar
Is the big connector capped off? If yes, then no, it doesn't branch off to anywhere.
Did you do the CKF bypass trick? Did you re-do the wiring for the 2nd O2 sensor? Did you search since both codes are common issues with a B-series into a 6th gen hatch?
Old Nov 14, 2007 | 08:13 AM
hatch96y7's Avatar
yes i did the trick bu thten code 9 come up and it runs worse.
i dont have a cat that will support the 2nd o2 sensor.
but i thought the 2nd o2 is only for the cat anyways.
the bung is not capped off.
the pin numbers i gave you are the ones lkeading to that bung.
there is about 6-7 wires .
then theres another bung that i had before but i figured out it was fr my primary so i wired that up and now my po2s works.
the shop that did my swap switched my wiring harness because thats not how my y7 harness was i just recently figured it out.
so know im trying to work with it.
but i am getting a chipped p06 ecu by the end of the week so maybe obd1 will be better
Old Nov 14, 2007 | 10:30 AM
hatch96y7's Avatar
up
Old Nov 14, 2007 | 10:59 AM
hatch96y7's Avatar
22
Old Nov 16, 2007 | 08:31 AM
hatch96y7's Avatar
up
sameb
Engine Management and Tuning
Jul 19, 2011 07:46 AM
grandtheftlunchbox
Mar 25, 2010 04:02 AM
krkline2gdsm
Jan 28, 2009 11:11 AM
vw eater
Jun 19, 2007 02:04 AM
geoscranny84
Honda Civic (2001 - 2005)
Apr 10, 2006 11:48 AM
