THe most important THIng??
Old Nov 13, 2007 | 07:47 AM
VTECboy97's Avatar
Default THe most important THIng??
Im thinkin about boosting my D16Y8 and i was wondering what are some really important things to change or re-do or get stronger of if i plan on boosting ??? appreciate the tips!!
Old Nov 13, 2007 | 07:55 AM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
Default Re: THe most important THIng?? (VTECboy97)
oil to the turbo
Old Nov 13, 2007 | 07:58 AM
B16B_coupe's Avatar
HRD PKR
Default Re: THe most important THIng?? (eggmygirl)
are you looking to keep the car daily or a weekend car?
Old Nov 13, 2007 | 08:00 AM
Padawan's Avatar
Darth ModerVader
Proper tuning is probably one of the most important and most commonly overlooked aspects of a turbo setup.
Old Nov 13, 2007 | 08:03 AM
VTECboy97's Avatar
Default Re: THe most important THIng?? (B16B_coupe)
It will be a daily driver
Old Nov 13, 2007 | 08:04 AM
B16B_coupe's Avatar
HRD PKR
if your looking to make like a high hp y8, i would rebuild the motor sleeved, etc
daily you can piece together a good kit for fairly cheap, and spend some good money on tunning and you will be set...
dseries.org has some good info iam sure... check it out
Old Nov 13, 2007 | 08:08 AM
VTECboy97's Avatar
Another quick questions. How much is a average for spending on a turbo set up ???????
Old Nov 13, 2007 | 08:11 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Try the boost forum - this might turn into a "Don't boost it!" vs. "Boost it!" topic since it's in the Civic forum, not the boost forum.
Old Nov 13, 2007 | 08:13 AM
95ProjectEJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECboy97 &raquo;</TD></TR><TR><TD CLASS="quote">Another quick questions. How much is a average for spending on a turbo set up ??????? </TD></TR></TABLE>
All depends on what your intentions are. You can piece a crappy one together for 1500+, get a full kit for 3k+, or a custom turbo setup for over 4k. Going turbo is not cheap what so ever if you want it done properly.
I have seen turbo's go for 700+ and the manifold/DT/DP go for 1k+ easy. Dont forget you still need the IC, WG, BOX, Oil/Vac lines etc etc.
Old Nov 13, 2007 | 08:26 AM
VTECboy97's Avatar
Default Re: THe most important THIng?? (95ProjectEJ1)
i KNow they are not cheap at all but i think i will have about 3500 to 4500k maybe even a little more, and idk where really to start getting parts or what i should start doing to get the motor turbo ready and i was looking at an ebay turbo get but its one of the little more expensive ones kinda and idk i just need a little guidence??
Old Nov 13, 2007 | 08:28 AM
When all is said n' done, what kind of whp #'s are you looking to get from this motor?
Old Nov 13, 2007 | 08:31 AM
VTECboy97's Avatar
im really hoping for at least 300 i would like a lil more but idk
osbunjosh
14
Nov 11, 2011 02:51 PM
mynameisMUDD
Jan 15, 2010 01:28 PM
greasemonky50
Mar 15, 2006 04:40 AM
cilvia
22
Nov 19, 2005 05:40 AM
titan2nv
Sep 6, 2004 05:16 AM
