crank pulley at tdc... searched.
so ive searched and searched google and honda tech. and im almost embarassed to ask this question but im very frustrated because all the recources say my crankshaft pulley should have a tdc mark on it and it does not have one the engine is a d15b2 am i missing something? i am thinkin i will have to pul the head and resort to putting it at top dead center by looking at the pistons or to stick something in the spark plug hole and wait till it gets to the top if i cant figure this out. i cant even find a picture of the d15b2 crank pulley to compare. and my freind said his crx (also a d15b2) does indeed have a mark.
any thoughts suggestions or answers to my problem.
you're not out of luck,,if you remove the crank pulley and look at the timing belt gear there should be a little groove on it,,and there is an arrow on the oil pump,,lining those up with each other and using the screwdriver in #1 cylinder should get you set..
Check out this thread. Mine was no longer colored, but it was there.
https://honda-tech.com/zerothread?id=1489047
