found some wheel that really like need some help
18" x 8.5" offset +35
18" x 9.5" offset +45
anyone have this size of rim on your ap1,
will fit right in or do you need to do something to your fenders?
thank!
thank!
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
your def gonna have to roll your fenders and run some negative camber... most likely a lil more aggressive than a UK spec... what are you lowered on?
i had mine done by a local guy... he actually did them for $20 which is really cheap... see if theres anyone thats in ur area that does them and have them do them at a meet... if not performance shops will typically run $50-100 for both fenders...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">215/235 roll fenders re locate bumper tabs</TD></TR></TABLE>
I would not run a 235 tire on a 9.5"... that is stretched out to the max... Even though it is safe to use I dont like that look feel...
Youll prolly be ok when everything is said and done, but as soon as you lower your car, your going to most likely run into some more problem...
to S2KILLA
if you what to use the wheel size i mention above with fender roll, what is the best offset for it without messing with camber.
thank!
thank!
on stock height that will look so bad cause it will stick out A LOT.
if you dont want to change camber and you want to use 8.5 + 9.5 you should be looking at LEAST in the 50's and up offsets.
what wheels are these?
