transmission oil leak
Hi,
i recently had an issue where my tranny was slipping out of 5th gear and someone on the forum told me its low on trans fluid, so i changed the trans fluid and i no longer have this issue. the oil that came out of the tranny was 1/2 quart rather than 2.4 quart which was really low.
but i still see some drops of oil on the ground from my transmission. last time i got the tranny oil changed from tires plus, they took 1 hr to find out the filler and drain plug and mistakenly must have tried to open the #13 bolt in the attached figure:
https://honda-tech.com/zerothread?id=2117471
the oil is leaking from the # 13 plug. i dont see any washer in that plug. what might be the issue ? what do i need to do to fix the leak ?
thanks in advance.
thanks in advance.
junk95civ
Feb 26, 2010 03:05 PM
CivicRaping
Mar 26, 2005 09:55 AM
