fan is not working
Old Nov 12, 2007 | 05:05 PM
4RODO's Avatar
Default fan is not working
So i just replace my radiator fan and fuse<(junkyard).starts up fine but when i sit in traffic it throws #6 code and it start to over heat?So now is it my ECT sensor or my fan assemble? d15 non-vtec advise is need!
brandon
Old Nov 12, 2007 | 05:58 PM
4RODO's Avatar
Default Re: fan is not working (4RODO)
bump
Old Nov 12, 2007 | 06:17 PM
B16B_coupe's Avatar
HRD PKR
replace the engine coolant temp sensor since thats what the code is for
Old Nov 12, 2007 | 06:38 PM
94c1v1cex's Avatar
Default Re: fan is not working (B16B_coupe)
replace the ECT and if that doesn't work try getting a new fan and not an junkyard one.
Old Nov 12, 2007 | 06:40 PM
B16B_coupe's Avatar
HRD PKR
Default Re: fan is not working (94c1v1cex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">replace the ECT and if that doesn't work try getting a new fan and not an junkyard one.</TD></TR></TABLE>
the junkyard van is prob fine, if the engine coolant temp sensor isnt working it does not know when to kick the fan on cause it dont know the engine temp.. so get yourself a NEW coolant temp sensor.
Old Nov 12, 2007 | 07:04 PM
95ProjectEJ1's Avatar
If you cant replace it right away then take a paper clip and stick each end of the clip into the fan connector (harness end). Its ghetto, but it will keep you from overheating.
Old Nov 13, 2007 | 06:33 AM
4RODO's Avatar
wow thanks guy ill try the sensor first.also how much yal think it would cost from
honda to get one?
Old Nov 13, 2007 | 06:40 AM
B16B_coupe's Avatar
HRD PKR
maybe 20 or so bucks.. call them
Old Nov 13, 2007 | 06:43 AM
Duane_in_Japan's Avatar
Nobody mentioned water flow issues or thermostat problems, are you sure you have good flow. Does your car not have a fan switch seperate from the ECT.
xpdude
Nov 5, 2009 05:39 PM
Rayz_Si
13
Feb 27, 2008 08:29 PM
DC5 Demon
Feb 6, 2006 01:50 PM
tianporn
15
Feb 20, 2005 10:56 AM
hardboiled egz
11
Jun 17, 2003 10:08 PM
