92 civic w/jdm gsr poor performance under load/cold idle
its my buddys car here is the ho down
installed b18c, after markets intake mani, stock gsr header, and custom fuel setup
car ran perfectly fine for 2 weeks, ran strong as hell
ecu went bad and got it replaced, its a p06 chipped...first off went the chip is out and he starts the car it sets code 1. but with chip in there is no cel
PROBLEM:
ok so the cars problem is mainly on load only, when ever he gives it gas above 30% throttle it starts to break up and not pull hard and start to sputter.....
and at idle when its cold it will break up as well when trying to rev.
tested
fuel pressure-ok
has new spark plugs, cap/rotor,coil..
possible a bad ignitor? wires?
please help my friend thanks
PROBLEM:
tested
fuel pressure-ok
inncorect timing possibly that is my best guess if your igniton sytem is working properly.make sure your getting spark. check timing
thebigone
Mar 21, 2009 04:00 PM
B16B_coupe
Nov 23, 2007 01:49 PM
