b20vtec ticking noise.
Old Nov 12, 2007 | 01:12 PM
B20BV's Avatar
Default b20vtec ticking noise.
i had my b20 vtec motor for about 2 months now, and recently it has started to make a ticking noise at round 2k rpm and up. the noise stops if i let go of the gas, it sounds like its coming from the head. i check my valve clearnece and is all ok, not really sure what it could be, has anyone come accros it before?
Old Nov 12, 2007 | 03:24 PM
arc_55's Avatar
I am not sure how pronouced the ticking noise is but i have seen valves that needed to be adjusted as bad as this situation. Check your valve lash as it is possible and an adjustment that many poeple overlook as a maintence.
Old Nov 12, 2007 | 08:37 PM
onepoint6i's Avatar
Default Re: b20vtec ticking noise. (B20BV)
lma's
Old Nov 12, 2007 | 10:31 PM
B20BV's Avatar
i have already checked for valve clearnce, no problem there. the ticking noise can only be heard at around 2k rpm and up. and when i start the car it gets really loud untill it goes down to idle.
Old Nov 12, 2007 | 11:21 PM
supermonkey84's Avatar
could be bent valves.... what head is on there?
Old Nov 13, 2007 | 10:26 AM
B20BV's Avatar
its a b16a2 off a 99 sir with a b20b block
Old Nov 13, 2007 | 11:40 PM
DA_PoWeR's Avatar
Could be valves or valve adjustments. But always be safe and check your oil.
Old Nov 14, 2007 | 11:23 AM
B20BV's Avatar
welll yesterday morning the tinking got really loud and somthing broke while i was going up a hill, the motor died and at the same time by batery died *** well luck i was still rolling and maneged to start it. the knocking now seems to be coming from the block. i started pulling the oil pan off to check the rods and bearings, maybe i can just replace the bearings..... yup its a bearing
Modified by B20BV at 2:20 PM 11/14/2007
Old Nov 14, 2007 | 02:10 PM
onepoint6i's Avatar
Default Re: (B20BV)
damn, time for a new block..
Old Nov 15, 2007 | 05:25 PM
B20BV's Avatar
im just ganna replace the bearing temporarly, while i get a new block, its to cold to do an engine swap where i live.
Old Nov 15, 2007 | 06:42 PM
onepoint6i's Avatar
Default Re: (B20BV)
how does the crank journal look?
Old Nov 18, 2007 | 09:56 PM
B20BV's Avatar
i measured it and turned out oval lol, but i sand it down a bit and managed to make it as round as i could till i get a new motor, and sanded down the connecting rod cap too because there was a little play between the bearing and the shaft. hopefully it will last for 2 or 3 months till i get my motor
Old Nov 21, 2007 | 03:47 PM
steven_highet's Avatar
Default Re: (B20BV)
You sanded what ?
Old Nov 22, 2007 | 03:40 AM
blackeg's Avatar
Default Re: (steven_highet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven_highet &raquo;</TD></TR><TR><TD CLASS="quote">You sanded what ? </TD></TR></TABLE>
lol...oh man
Old Nov 22, 2007 | 01:09 PM
B20BV's Avatar
the crank shaft, it wasnt that smooth anymore.
Old Nov 23, 2007 | 12:52 PM
Default Re: (B20BV)
You sanded your crankshaft by hand ?
Old Nov 23, 2007 | 01:55 PM
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20BV &raquo;</TD></TR><TR><TD CLASS="quote">i had my b20 vtec motor for about 2 months now, and recently it has started to make a ticking noise at round 2k rpm and up. the noise stops if i let go of the gas, it sounds like its coming from the head. i check my valve clearnece and is all ok, not really sure what it could be, has anyone come accros it before?</TD></TR></TABLE>
had the same problem with my gsr block...luckily i swapped it to a b20 block before i did more damage to it...
Old Nov 24, 2007 | 04:23 AM
B20BV's Avatar
i managed to get it pritty round though, its not ticking anymore, but im not revving it past 3k, its only a temporary until i swap my other b20 in just waiting for the right wether.
Old Nov 24, 2007 | 05:22 AM
blackeg's Avatar
Default Re: (B20BV)
what grit sandpaper did u use
Old Nov 26, 2007 | 07:42 PM
lsdB16aEj1's Avatar
Default Re: (blackeg)
couldn't it just be a noisy injector?
Old Nov 26, 2007 | 11:05 PM
quik1's Avatar
Default Re: (lsdB16aEj1)
Thats crazy!! Never would have done that. LOL "Pretty Round"
Old Nov 27, 2007 | 10:14 AM
snowseeker's Avatar
Default Re: (quik1)
OMG LOL! I'm in to see what happens next!
Old Nov 27, 2007 | 10:15 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdB16aEj1 &raquo;</TD></TR><TR><TD CLASS="quote">couldn't it just be a noisy injector?
Not anymore!
Old Nov 27, 2007 | 10:24 AM
HondaKid936's Avatar
Default Re: (snowseeker)
x2 homie lol im in to see whats next lol
Old Nov 28, 2007 | 11:08 AM
B20BV's Avatar
no it wasnt an injecter, once i opend it up i could move the connecting rod with my hand.. hey i no its stupid for sanding it round again but hey its been a week and still running good, like i said just a temp for now i dont really care if it goes again i ve got a new block.
