d16z6 in a 2000 civic? need some help!
Old Nov 12, 2007 | 12:15 PM
biggun's Avatar
Default d16z6 in a 2000 civic? need some help!
i just bought a d16z6 engine for my civic 2000,
i had a 1.6l d16 NON-vtec
now its a 1.6l VTEC
will the VTEC worked if i use my old ECU?
and its weird cuz on the motor head it doesnt say vtec but i checked over the internet and all d16z6 are vtec... can anyone confirm that for me
thx
Old Nov 12, 2007 | 03:58 PM
Crazydave's Avatar
Default Re: d16z6 in a 2000 civic? need some help! (biggun)
yes the d16z6 is vtec motor
I'm speaking out my *** on this. and it will probably come back to bite me... but I think you are gonna have some issues, putting a obd1 motor in a obd2 car. the computer will be at least looking for a 2nd o2 sensor, you will have to wire up the vtec, and i think get an ECU for a d16z6
most people don't back convert to an older engine.
Old Nov 12, 2007 | 04:31 PM
biggun's Avatar
Default Re: d16z6 in a 2000 civic? need some help! (Crazydave)
allright so the best thing to do for me is to get a d16z6 ecu??? cuz i can get one on eb*y right now... anyone can confirm this for me? and are u sure that my 2000 SE civic is obd2?
and other than than do you think ill have other issues... ?
Old Nov 13, 2007 | 09:09 AM
Crazydave's Avatar
I would definetly do some searches and research before doing anything. and don't depend on only what I said..... you need to do some research.
there are some conversion harness on the web:
http://www.evasivemotorsports....RNESS
Old Nov 13, 2007 | 09:52 AM
biggun's Avatar
i got a civic 2000 with a D-series transmission , and i just bought a d16z6 engine.. the only thing i want to know is if i got the Z6 ECU will i be able to install that in my car without any other issues
thx
Old Nov 13, 2007 | 12:30 PM
MeanGreenMachine's Avatar
i believe that you can use the obd2 engine harness on the obd1 z6 motor. youlll just need to get a obd2-obd1 distributor adapter @ rywire.com i think, every thing else should plug in. now when it comes to the ecu, you may need a obd2-obd1 ecu conversion harness and of course the respective p28 obd1 ecu.
do some more research before you go off doing what we told you, do the research to verify...
Old Nov 13, 2007 | 05:22 PM
Aquafina's Avatar
Default Re: d16z6 in a 2000 civic? need some help! (MeanGreenMachine)
I put a Z6 in my 96 after throwing a rod in my LX/VTEC.
You'll need the complete Z6 longblock
OBD2B-OBD1 conversion harness
P28 ECU
some wire to wire in VTEC
OBD2B 240cc injectors
92-95 fuel filter
Repin the dist plug (two of them have to be spliced).
blackEGFTW!
16
Jul 11, 2008 10:24 AM
blkroze4
May 30, 2007 06:51 AM
jfrase06
May 19, 2007 07:04 PM
commotion
Jul 25, 2006 09:50 AM
