Motor swap into a 92 Civic VX - 7 wire O2 question ???
Old Nov 12, 2007 | 10:25 AM
Turbo O's Avatar
Default Motor swap into a 92 Civic VX - 5 wire O2 question ???
Hey,
I'm dropping a B20Vtec swap into a 1992 VX hatchback, the economy version. This VX has the most wire just for the O2 sensor, I think theres atleast 5, maybe more.
Now my question is:
Do I have to do anything special for this car to accept the programming, which is Crome??
Do I have to change out the harness for a harness with the regular 4 wire O2, like a DX one, or will I be able to still use this crazy Vx one???
Modified by Turbo O at 3:39 PM 11/12/2007
Old Nov 12, 2007 | 10:30 AM
BlueIntegraBoy's Avatar
Default Re: Motor swap into a 92 Civic VX - 7 wire O2 question ??? (Turbo O)
The VX O2 sensor only has 5 wires. I don't know what you are looking at. As far as an O2 sensor for your B20/VTEC swap, you will need to convert to 4-wire. It won't be a problem if using an OBD2 B-series harness. You'll only need to swap a couple of wires on the shock tower.
https://honda-tech.com/zerothread?id=644434
Old Nov 12, 2007 | 02:40 PM
Turbo O's Avatar
Default Re: Motor swap into a 92 Civic VX - 5 wire O2 question ??? (Turbo O)
yeah I meant 5 wires.
thanks for the link.
halfkoreanboy
23
Feb 4, 2011 06:03 PM
shivic
Aug 25, 2004 01:57 PM
TriK
Jul 2, 2003 10:56 AM
H23vtecEG
May 18, 2003 05:36 AM
SOUNDEFFECTS
Jan 23, 2003 12:22 PM
