Civic vx o2 sensor question
Any of the civic vx owners out there know of a cheaper alternative to replacing the 5 wire o2 sensor,i bought a d15z1 swapped eh dx hatch and it doesnt have the o2 sensor at all,previous owner must have kept it. but is there like a genric one available im getting bad mpg and dont want to spend a lot on a o2 sensor
Any help would be great
Re: Civic vx o2 sensor question
boschsshchshshhh and some other aftermarket sensors are bit cheaper and work fine as well. i ve used boschshchshchshhsh sensors in 3 of my cars and they all work fine and pass emissions and all.
check around online theres many stores sell them.
just make sure its a 5 wire, sometimes they might list the wrong item as compatible.
im assuming you have the full vx harness but it can be converted to support a four wire o2 sensor by swapping a couple wires at the o2 disconnect and a couple at the ecu disconnect fairly simple just google 5 wire 4 wire o2 conversion. i wouldnt recomend getting any cheap wide band o2s from my experience theyll always throw a light and run like crap. if you understand the diagrams let me know i have my own 1 i used for my conversion.
as far as I know.....all o2 sensors are the same....as long as you get the same number of wires....4 is standard...5 is heated I believe.
I have a 4 wire ford 02 sensor after cat in my car....because it was free....and it works fine....great gas mileage, no CEL.
Ive heard....the ford mustang 4 wire is the cheapest 02 sensor to buy......
bosch is not bad, but its cheaper than stock sensor. like i said before i ve used bosch in 3 different cars with no issues.
from wikipedia:
It was developed by the Robert Bosch GmbH company
just because its not made by one of the HONDA brands doesnt mean its bad.
most of the honda parts are not even made by same company.
just like alot of car speakers are not made by the well known car speaker manufacturers.
from wikipedia:
But would i be able to use my vx non cali ecu with a four wire,i dont mind loosing a few mpgs as long as i still get around 45mpg
Thanks
Im willing to try a bosch if itll work, thanks
My other option is to get my ecu tuned and delete the oxygen sensor completely or something, I was told by a guy. He said he could tune my ecu and he will delete my o2 sensor and my ecu will run what he tunes it to and never change,this is the option im leaning towards and no check engine for o2 or anything and never have to worry about a o2 sensor.Because i cant find a decent priced L1H1 5 wire o2 my tune would be cheaper and never have to worry about the o2 again.....Any pros and cons to this?
Thanks
Thanks
Seagull Management
Thanks
Thanks
You'll see O2 sensors for the VX in the $300-400 range. The NTK 24300 should be a direct replacement, and is considerably cheaper (though as it's wideband, it's more than your "average" sensor.)
$189 - http://www.oxygensensor.net/ntk_o2/24300.php
The O2 sensor is really at the heart of the VX in terms of fuel economy... without the correct part, you're left with a Honda that gets above average mpg (instead of amazing mpg) and only 92hp. The upside is that it should actually pay for itself.
o2 sensor is platinum coated plates very close to eachother that react to oxygen.
all it needs to do is give out correct reading to the ECU.
bosch invented the damn things, do you think they are incapable of making them to honda standard?
people are brainwashed by this OEM bullsht with no real evidence to back it up.
you dont buy the cheapest available part because it will break, but you dont have to buy the most expensive either. theres always "reasonably priced" part you can get and be fine with it.
ntk is one of those brands as well.
Seagull Management
I will agree with you on that, and they are much cheaper than OEM.
i never said bosch is the only way to go. i can say same thing about car audio, i work in the field and i know a bit more about quality of different brands. but it doesnt mean that you cant do more with less. your knowledge sometimes makes up for the price difference.
im sure its better, but is it worth paying tripple the amount? sometimes it doesnt.
especially with hondas and when you are not planning to keep the car for more than few years.
people dont care if you put all OEM super expensive parts, they just want to buy your car as cheap as they can,
btw i had the bosch on my car for last 4 years, and so did my friend with no problems.
would i spend over 200 dollars on the OEM o2 sensor hell no!!!! unless i know for sure that i want to keep that car for the rest of my life.
btw EG8: not to start an argument but im sure bosch has pretty good QA. and chances are alot of honda motors are not really operating at their best. with all the half assed builds and lack of maintenance, honda O2 sensors are probably designed to take much more abuse than regular O2, but if your engine is in good condition then it should work fine.
Im actually running it on a p28 right now with no o2 at all,my mpg is 200ish to a full tank,but it actually takes off fast with the stock p28 and i was going to trade a guy my p28 for a p07 non cali version,but since i cant tune it,i guess im just going to keep the p28 and just delete o2 sensor and tune it and lower the vtec to 2500,if i get 38 to 45 mpg ill be happy lol....Thanks for all the info and letting me know about the p07....I think tuning the p28 would be more worth it with o2 delete than spending 200 to 300 on a o2 sensor
Seagull Management
Thanks for the info,i dont know much about bosch,the d15z1 mine came with has bosch spark plugs in it right now,it doesnt seem to like bosch spark plugs,it sputters at idle and shakes hard when im cruising in second gear,but im not putting bosch down at all i just heard vx motors are very picky about plugs too. But the bosch o2 sensors ive never used
Personally, if you want the VXs absolutely phenomenal mileage you'll need a P07 and a proper 5 wire wideband. I can almost guarantee you a Bosch just wont work for you here (yes the 4 wire unheated ones will usually work if that's what the car calls for, but I haven't seen anyone yet run a Bosch O2 sensor in a VX and have it work properly (either keeps throwing a code or the light wont go out) If you're going to chip and tune that P28 in a dyno it's probably going to cost you at least $200 - $300.
Bosch plugs suck in a Honda, i'm sure they're ok in a VW or something, but everytime i've seen someone put them in a Honda they foul.
Still needs to be set lower on a p28 to run the d15z1 properly,with fuel and what not plus i dont see my d15z1 hitting 4500 rpms daily lol i barely push it to 3000,it is vtec though 100 percent ,and to let you know my vtec isnt hooked up at all and it still pulls on low rpms just looses power after 2nd gear because of the transmission,but its not a race car at all,just a fun daily driver and to save a little on gas,maybe in the future ill put a jdm d15b vtec when this z1 goes
Yea my z1 seems to sputter at idle i hate it lol,im swapping the plugs out for the recomended ngk,im guessing thats what the jerking is when i cruise in second at low speeds when there is traffic
Seagull Management
Ah i see,yea its in a dx hatch i know the guy before me didnt wire it in, ill probably do that sometime this week before i get it tuned,thanks
1993eghatch
09-24-2010 05:52 PM
EARLdaSQUIRREL
01-13-2003 07:09 PM
