97 d16y8 into 93 EG [HAVE SEARCHED]
Old Nov 12, 2007 | 07:22 AM
Black-Ty [EG6]'s Avatar
Default 97 d16y8 into 93 EG [HAVE SEARCHED]
like the title states i have a complete 97 d16y8 im puttin in my 93 dx EG for boost.
my question is should i convert the car to obd2 to match the engine harness and ecu i have or use the harness i have in the car and jus wire for vtec and use a p28 ecu.
if i stay obd1 do i have to get an obd1 dizzy or can i keep the y8 dizzy?
if i have to convert what all do i have to change?
anyone that can help thank you.
Old Nov 12, 2007 | 07:26 AM
CRX Toad's Avatar
Default Re: 97 d16y8 into 93 EG [HAVE SEARCHED] (Black-Ty [EG6])
https://honda-tech.com/zerothread/1998336
I'd stay OBD1, so you will be able to keep your current wiring and need to get the OBD1 distributor. You will need to wire in the VTEC harness but that would be easy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-Ty [EG6 &raquo;</TD></TR><TR><TD CLASS="quote">]
anyone one else keep ur dumb *** comments to urself!</TD></TR></TABLE>
That is really the fastest way to get your thread filled up with flaming.
Old Nov 12, 2007 | 07:27 AM
97Ej6mike's Avatar
Stay OBD1 for the sake of the p28 cause you can have them chipped and tuned, OBD2 is a pain.
Depending on the wiring harness that your using, i think the injectors (if they obd2) are a different shape from OBD1 plugs (if you were to use an OBD1 harness).
Old Nov 12, 2007 | 07:29 AM
nix94delsol's Avatar
sell your y8 and get a z6, its pretty much the same thing but its OBD1 and less of a pain in the ***
Old Nov 12, 2007 | 07:30 AM
Default Re: (97Ej6mike)
thanx guys
and i have a dx harness in the car
so i should get a obd1 dizzy? like a z6?
and obd1 injectors?
anything else?
Old Nov 12, 2007 | 08:11 AM
raphael's Avatar
just use the injectors nd dizzy from the d-series in the car already. they are interchangeable
Old Nov 12, 2007 | 08:48 AM
teal_dx's Avatar
Default Re: (Black-Ty [EG6])
dx dizzy will fit D16y heads. D16z6 dizzy will NOT. use yours
put your DX engine harness on the D16y7. Now your dizzy plugs right in. Swap your OBD1 injectors in as well, obd2 injectors are different than your dx harness.
if you have power steering...
may need to re-use your dx power steering pump, the pumps both bolt to either engine's brackets, but the connection on the end of the barbed fittings are different. it's easier to change PS pumps than it is to change barbed fittings.
Re-use your OBD1 alternator with the round plug to match your dx harness... OBD2 have a squarish plug.
It might be easier for you if you just re-used your entire intake manifold, since the IAT sensor wires will need to be extended to the intake arm, and you'll have to swap injectors anyways.
Old Nov 12, 2007 | 09:04 AM
Default Re: (teal_dx)
thanx everyone u all r a REAL help!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx &raquo;</TD></TR><TR><TD CLASS="quote">dx dizzy will fit D16y heads. D16z6 dizzy will NOT. use yours
even if its a dizzy from a d15?
and i have a d16y8 not y7 will the dx dizzy work on a vtec motor?
Old Nov 12, 2007 | 10:46 AM
teal_dx's Avatar
yep your d15b7 dizzy will bolt up to the d16y8 head with no problem. I ran the same setup a while back.
Old Nov 12, 2007 | 11:51 AM
cool bro thanx for all ur help
Old Dec 4, 2007 | 09:33 AM
iluvhisEG6's Avatar
hey babe let me kno when you get that number for me to call about the engine stand...
Old Dec 4, 2007 | 09:37 AM
Ron454321's Avatar
Default Re: 97 d16y8 into 93 EG [HAVE SEARCHED] (iluvhisEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvhisEG6 &raquo;</TD></TR><TR><TD CLASS="quote">hey babe let me kno when you get that number for me to call about the engine stand...</TD></TR></TABLE>
Wow, thats one of the dumbest responses I've seen, sounds like you two may be datin, why the need to post on HT for something like that, you two can' talk on the phone?
Old Dec 4, 2007 | 09:40 AM
Default Re: 97 d16y8 into 93 EG [HAVE SEARCHED] (Ron454321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron454321 &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, thats one of the dumbest responses I've seen, sounds like you two may be datin, why the need to post on HT for something like that, you two can' talk on the phone?</TD></TR></TABLE>
i dont think anyone was talkin to u bro
keep your dumbass comments to urself
Old Dec 4, 2007 | 09:45 AM
iluvhisEG6's Avatar
wow i guess haha people are way too serious on here haha
anywaysss
did you get that # or do i need to look it up love?
Old Dec 4, 2007 | 09:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvhisEG6 &raquo;</TD></TR><TR><TD CLASS="quote">wow i guess haha people are way too serious on here haha
anywaysss
did you get that # or do i need to look it up love?</TD></TR></TABLE>
check your PM
Old Dec 4, 2007 | 09:48 AM
iluvhisEG6's Avatar
got it thanks! ill let you kno what happens after i talk to em
warrick
Mar 27, 2009 04:01 AM
BoostedRedline
Apr 14, 2007 01:22 PM
haroldthefly91crx
Sep 13, 2006 04:35 PM
CRX_Control
Aug 10, 2004 06:42 PM
hYbRiD EeEkAy
Nov 14, 2003 01:34 PM
