Wierd Noise at Idle
Old Nov 12, 2007 | 07:20 AM
Dicorp's Avatar
Default Wierd Noise at Idle
This recently started happening, out of nowhere. If im sitting at a red light, car in gear, clutch depressed, everything sounds fine. the second i put it into neutral and let go of the clutch, this low pitched whine is heard until i press down the clutch again. the only thing that happened to the car recently, is my muffler tip fell off but that cant be it. what can this be?
Old Nov 12, 2007 | 09:04 AM
Dicorp's Avatar
Default Re: (mgags7)
well i dont feel any shifting problems with the transmission, or the clutch. car drives really good
Old Nov 12, 2007 | 09:08 AM
mgags7's Avatar
It would drive fine in the initial stages of the bearing going bad, depending on the situation.
Old Nov 12, 2007 | 09:09 AM
mgags7's Avatar
Whoa whoa hold on.
I misread your post.
You have one of two problems, either your throwout bearing is going bad, or your input shaft bearing is.
Apologies.
Does the sound get louder with rpm?
Old Nov 12, 2007 | 10:33 AM
Dicorp's Avatar
well theres also a whistling noise present when i accelerate, which may be a belt. but this one doesnt get any louder, at leats i cant hear it over my CAI and busted muffler
Old Nov 12, 2007 | 11:26 AM
mgags7's Avatar
A loose belt will be a lot louder than a "whistle," it will be more like a "squeal".
I'm willing to bet it is the throwout bearing, but try just putting it in neutral, letting the clutch out, and revving it, see if you can hear what the sound does.
Old Nov 12, 2007 | 11:29 AM
dagle's Avatar
when bearings go out, you just keep driving until ur next clutch change right? o_O assuming u can deal with the annoyance
Old Nov 12, 2007 | 11:46 AM
Dicorp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">A loose belt will be a lot louder than a "whistle," it will be more like a "squeal".
I'm willing to bet it is the throwout bearing, but try just putting it in neutral, letting the clutch out, and revving it, see if you can hear what the sound does.</TD></TR></TABLE>
well its somewhere between the too, only present when i touch the gas pedal, even lightly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle &raquo;</TD></TR><TR><TD CLASS="quote">when bearings go out, you just keep driving until ur next clutch change right? o_O assuming u can deal with the annoyance</TD></TR></TABLE>
well the previous owner put in a performance clutch and there's only 124K on the car, a little too early for that i would hope
Old Nov 13, 2007 | 06:35 PM
Dicorp's Avatar
well i got confirmation that its the throw out bearing. now how much potentail tranny damage is possible driving it the way it is?
josephemorgan91
Honda Civic (2001 - 2005)
Nov 21, 2015 01:53 PM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
wessieball
Feb 25, 2009 12:44 PM
Full Race A6
Sep 7, 2004 02:12 PM
BauleyCivic
Aug 13, 2003 08:35 AM
