Installing new distributor.
Can i just bolt the new distributor on or are there things that have to be done to keep the timing correct. obd1 distributor and first gen b16a
thanks in advance.
[Modified by fire7882, 9:28 AM 6/24/2002]
thanks in advance.
You don't have to do anything special with the timing. If you look at the distributor the slot on the end is not centered. The intake cam is the same way. So the distributor when installed only will go in one way. Basically pop the bad boy in and its ready to fire up. Hope I was of help.
taguchi09
Jun 11, 2011 04:52 PM
irishgod247
Mar 13, 2007 10:35 AM
