Lighting HID/Xenon kits, Retrofits and Associated Topics
retro fit
Old Nov 11, 2007 | 06:04 PM
VTEC_PRODUCTION's Avatar
Default retro fit
will the bmw e46 projectors fit in the 94-01 headlight? and also do they shine blue because i saw this in a picture but it could be falsely advertised...
Old Nov 11, 2007 | 07:10 PM
bpr0422's Avatar
Default Re: retro fit (VTEC_PRODUCTION)
Register: HIDPlanet Forums
Read: HIDPlanet University
It would also help to know what kind of car you are going to retrofit. Also what kind of headlight you are going to retro, OEM or aftermarket.
Old Nov 11, 2007 | 07:17 PM
androO's Avatar
yes siR! get your answers from hidplanet.com/forums
Old Nov 11, 2007 | 07:37 PM
Default Re: retro fit (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">Register: HIDPlanet Forums
It would also help to know what kind of car you are going to retrofit. Also what kind of headlight you are going to retro, OEM or aftermarket.</TD></TR></TABLE>
i told you its going into a 3rd gen teg. and i really dont want to register at anymore sites than i have to. so if someone knows the easy yes or no question it would really help. i have a 94 teg stock headlights.
Old Nov 11, 2007 | 08:34 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">i told you its going into a 3rd gen teg. and i really dont want to register at anymore sites than i have to. so if someone knows the easy yes or no question it would really help. i have a 94 teg stock headlights.</TD></TR></TABLE>
you said what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">will the bmw e46 projectors fit in the 94-01 headlight? and also do they shine blue because i saw this in a picture but it could be falsely advertised...</TD></TR></TABLE>
all i see is BMW E46 in 94-01 headlight... what car?
The light color is based on what bulb you plan on running... 4300k is OEM and is the best choice, it outputs the whitest light, and gives you the best output. bluish is about the 6000k to 8000k. 12000k is purple ish and useless
Combine that with some good projectors, and you will be happy.
the bmw E46 is a bi-xenon i think, and based on what i've read at hidplanet, its not the best projector out there... the TL projector actually out performs it.
you really should register at HIDPlanet, because all your questions, even those you haven't asked, have already been answered there.
this is a diagram that was posted there: http://img.photobucket.com/alb...g.jpg
I dunno what your oem projector size is.. but what you are thinking of doing has been done before.. just look for it...
here is another site: http://faqlight.carpassion.info/
Old Nov 13, 2007 | 01:29 PM
B20inDCinLBC's Avatar
You can fit TSX projectors in your car.. That blue you see is the cutoff line. Just a color the projectors make because of the cutoff shield cutting the beam pattern. So you can only see the blue at the cutoff line.
Old Nov 13, 2007 | 04:09 PM
dwolsten's Avatar
The answer is yes, the e46 projectors will fit in a 94 Integra headlight; those are the projectors I'm using in my Integra. They come in both bi-xenon and regular varieties.
I don't blame you about registering at websites; it's a pain in the *** to have to register just to go read a few things. It's just like those stupid newspaper sites like nytimes.com which want you to register just to read some article that someone sends you a link to. It also sucks because it keeps Google from spidering the site and making all the information available from a google search. I can understand requiring people to register in order to post messages of course, but requiring it just for reading is lame.
As for whether the e46 is "better" or "worse" than other projectors is probably subjective. Many people seem to like the TSX projectors better. I can't really say either way, but from my reading it seems like some people are more interested in what kind of colors they can get at the cut-off line than what kind of actual usable light output they get for seeing the road, so be aware of this when people say one projector is "better" than another. Your criteria for "better" may be different from theirs. Regardless of all this, the e46 might be more easily or cheaply available on places like Ebay; so cost may also be a factor.
If you're using the e46 bixenon projectors, be warned you'll need a special circuit to trigger the solenoid, because it uses 3 wires instead of two. There's a circuit diagram on HIDplanet showing how to use a relay and some resistors and capacitors and diodes to do this properly, or you can buy quarter-sized circuit boards on my website that do the same thing which are very easy to install.
Old Nov 13, 2007 | 05:52 PM
TSX is better than E46 when you're talking about output.. here..look at this to compare..
The left projector is the TSX projectors in the housing.. and The right is E46 outside of the housing.
The tsx is just more crisp and has a sharper cutoff. Keep in mind, that one the projector is in the housing, the lense flute the light output a bit, but the TSX still outperforms the E46. IMO, save your mula for the TSX. You might as well
Old Nov 13, 2007 | 06:04 PM
bpr0422's Avatar
Default Re: (B20inDCinLBC)
isn't the tsx projector cheaper than the e46 projector???
thing is the tsx is a single beam... if he wants bi-xenon.. he should save up for a TL projector and a clear ZKW lense
Old Nov 16, 2007 | 02:42 PM
potmilkz's Avatar
VTEC... to answer your question.. yes it would.. my friend did it but theres a slight problem due to that its way bigger than the origianal housing in the back.. your going to have to find some way to block the back so that it prevents from fogging up
Old Nov 16, 2007 | 04:13 PM
Default Re: (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">isn't the tsx projector cheaper than the e46 projector???
thing is the tsx is a single beam... if he wants bi-xenon.. he should save up for a TL projector and a clear ZKW lense</TD></TR></TABLE>
no, e46 is cheaper. It's **** to me.
Tl projectors, I dont know if it'll fit. Not sure. Anyways. TL projectors are 200, give or take 20 bucks. ZKW lense go for 300. Got a lot of saving to do.
spAdam
Honda Fit
Nov 2, 2015 10:37 AM
2+2Door
Jul 13, 2007 12:37 PM
bigwavedave
Honda Fit
Jun 4, 2006 08:46 PM
GreenTeaLS
Mar 22, 2005 01:24 PM
ptsiu
Mar 8, 2004 10:22 PM
