throw out or input shaft bearing....
d16y8...99 ex coupe....
i get a funny noise like a ticking noice when the clutch is out
but when i push it in, it stops.....
but when i drive into first it sounds as if there is a whinding noise..
as if the motor is whinding up...?
any help?....
thinking its either input shaft or throwout bearing?...
any help?....
Its your input shaft bearing. It will only get worse the more you drive it. Eventually the bearing will bust apart and possibly ruin the rest of your transmission. I had this problem before. Here is the write up that convinced me that I could do it myself. It is a complete walkthrough with pics. Good luck!
https://honda-tech.com/zerothread?id=596873
Unphzd
Feb 21, 2012 07:16 AM
Pbanto
Apr 8, 2009 05:07 AM
