will this fit my gsr?
hey guys i have a 97 gsr that needs a water pump. i have a new water pump left over from an old build its for a 99-2000 si it says 22t on the gear, and p75 on the blade on the back. will this fit my gsr? thanks guys.
adam
adam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatch3 »</TD></TR><TR><TD CLASS="quote">sweet thanks guys!! im guessing a gsr uses a different timing belt anyone one know?</TD></TR></TABLE>
Yes, a GSR uses a different timing belt than the Si since the B18C block is taller than the B16A.
The water pump for the 2000 Si has p/n 19200-P72-013, which is the same as a GSR. Use the GSR timing belt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
The water pump for the 2000 Si has p/n 19200-P72-013, which is the same as a GSR. Use the GSR timing belt.</TD></TR></TABLE>
x2. had the same problem 2 weeks ago.
eg:R
Aug 27, 2005 06:43 AM
