92 civic eg car does not start, i need some input
The car worked great, i took out the motor to install a lsd on the tranny, put everything back, and now the car does not start. it sounds like it is but it does not. The car has spark i check every spark plug wire the the spark plug to see if i had spark, and all of them do. I am getting lots of fuel, into the motor, when i take out the spark plug they smell like gas, so then i though it might be the timming. everything lines up from the cam sprokets the motor is at top dead center, and nothing, it also cranks but does not start. i have the ground connected for the engine harness, i have the tranny cable connected, and the one for the valve cover. I do not have the vechile sensor connected, do to the gear does not line up with the kaaz lsd. i checked all fuses and they are all good, i do not get a engine code either. i am stuck, any help will be great!
92 civic dx
ls/vtec
gt3076r
1 year ago in my DA
92 civic dx
ls/vtec
gt3076r
1 year ago in my DA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 »</TD></TR><TR><TD CLASS="quote">I FOUND IT!!!!!!!!!!!! IT WAS THE DISTRIBUTOR THE PART THAT GOES TO THE CAM WAS 180 DEGREES OFF, IT WAS FIRING TO CYLINDER 4 INSTEAD OF 1</TD></TR></TABLE>
Haha. That was what I was about to saiy. Happen to me a few years back and it took me 3 months to figure it out. Glad you got it staighten out.
4 door beast
Mar 18, 2012 09:06 PM
Mechatronics
Jul 23, 2009 01:36 PM
