d16z6 je pistons
Old Nov 10, 2007 | 05:47 PM
dravesef's Avatar
Default d16z6 je pistons
i've done the search and seen all the threads, just making sure i have it right. if i put my z6 pistons in my y8 the will have a little higher compression? right? they a 8.5 so i don't mind bumping it up a little if i read right. thanks for your help and info!
Old Nov 11, 2007 | 01:07 AM
Syndacate's Avatar
Default Re: d16z6 je pistons (dravesef)
I think you'd lose compression if you put Z6 pistons in a Y8 block, the Z6 has like .4 lower compression ratio.
So assuming they make a Z6 8.5 comp, they'd probably be around 8 flat in a Y8...
That's all theory, b/c the Z6 runs like a 9.14 I think, and I think the Y8 runs like a 9.6 - so uhh, 8.5 in a Z6 would be a bit diff in a Y8 b/c I think the crank offsets are the same.
O.o
Bump for ya.
Old Nov 11, 2007 | 06:48 AM
themikewoo's Avatar
Have you tried D-series.org?
Old Nov 11, 2007 | 09:00 AM
onefine99's Avatar
im prett sure the y8s head is smaller combustion chamber than the z which would raise compression
Old Nov 11, 2007 | 09:31 AM
dravesef's Avatar
i read through a bunch of post about this when i did my search, and i thought if you put y8 pistons in a z6 it lowers the compression, so, if i you put z6 into a y8 it raises the compression
Old Nov 12, 2007 | 04:51 PM
onefine99's Avatar
Default Re: (dravesef)
i think your right i know the y8 has dish pistons and a smaller chamber so the z pistons which are not dished with the smaller chamber head you would gain comp
Old Nov 12, 2007 | 05:08 PM
yoffer's Avatar
Banned
Nope you will lose compression if you put the z6 pistons into the y8. Stock CR for a y8 is 9.6096, used with just z6 pistons you will get 8.9391. So YES you will lose compression if you use the z6 pistons. I got these readings from http://www.c-speedracing.com/h...c.php
Old Nov 12, 2007 | 05:09 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dravesef &raquo;</TD></TR><TR><TD CLASS="quote">i read through a bunch of post about this when i did my search, and i thought if you put y8 pistons in a z6 it lowers the compression, so, if i you put z6 into a y8 it raises the compression </TD></TR></TABLE>
It's possible, I don't know for sure b/c the heads are slightly different, but the Y8 runs like a 9.6 CR while the Z6 runs like a 9.2 CR, and I think they run the same offset crank. So uhh, iono anything about how their heads compare, that'd be the deciding factor.
Old Nov 12, 2007 | 05:10 PM
.:Swig:.'s Avatar
Default Re: (Syndacate)
i dont know much about dseries but i think the ZC pistons are better than the z6 or y8 if you want a higher compression.
Old Nov 12, 2007 | 05:12 PM
Syndacate's Avatar
Default Re: (.:Swig:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Swig:. &raquo;</TD></TR><TR><TD CLASS="quote">i dont know much about dseries but i think the ZC pistons are better than the z6 or y8 if you want a higher compression.</TD></TR></TABLE>
He's rolling back the CR, 9.2 (stock) &gt; 8.5 (his JE new pistons) - he's probably making a nitrous engine or plans on boosting.
Old Nov 12, 2007 | 05:14 PM
.:Swig:.'s Avatar
ah i thought he just wanted to change out pistons for higher comp.
Old Nov 12, 2007 | 05:25 PM
yoffer's Avatar
Banned
o, i thought he wanted MORE compression. even still with just the pistons the cr will only be 8.9
99hatch
Feb 1, 2005 08:36 AM
platinum00
Oct 25, 2004 08:55 PM
Burke
Oct 13, 2004 01:44 PM
pip9
Jul 12, 2004 05:10 PM
