Rewiring shell dash harness?
Old Nov 10, 2007 | 01:12 PM
importfan2's Avatar
Default Rewiring shell dash harness?
so as most of you know that I have a 98 shell im been building forever...well now that the motor is complete and is in the car... the friendly theives they are cut my harness on the drivers side right before the fuse box... (thieves).....so i got another cabin harness from another 98itr....now my dash harness is from an older obd1 teg... i was told that there are all the same for that harness....
so thats somewhat my situation...
one other question is what is the differences of obdII A & B? I have used the SEARCh button...been on here 4 years..just cant find my answer im looking for...so if u guys could help a Hype R fella out.....
HERE IS SOME PIX... i"ll take some pics of the motor later today
THIS IS WHAT I'M DEALING WITH RIGHT NOW
Old Nov 10, 2007 | 01:43 PM
Comp97GSR's Avatar
Default Re: Rewiring shell dash harness? (importfan2)
The differences between the 97 and 98 ITR which are both OBDIIA is huge. Between OBDIIA and B I am sure it is huge.
I would get as many wiring diagrams from each of the model years you have wiring from and go from there. I wish I could be more help. Hoochin and Bradstard should have plenty of info for you too.
If you need it, I have the interior ABS harness and computer available.
Good luck with the rebuild.
Old Nov 10, 2007 | 01:45 PM
Comp97GSR's Avatar
Default Re: Rewiring shell dash harness? (Comp97GSR)
BTW, Eric95LS may have an OBDII dash harness. I think they use the same connectors but would require repinning.
Old Nov 10, 2007 | 02:08 PM
importfan2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">The differences between the 97 and 98 ITR which are both OBDIIA is huge. Between OBDIIA and B I am sure it is huge.
Good luck with the rebuild.</TD></TR></TABLE>
i thrashed the abs completly...redid my brake lines and put in a 40/40 proportioning valve in for that....
Old Nov 10, 2007 | 02:09 PM
importfan2's Avatar
im gonna try to plug in everything that i have.. and see exactly whats missing its been a minute since i have even stared at her..cuz every time i do ------
Old Nov 10, 2007 | 02:42 PM
94rs-turbo's Avatar
well if you have 98 harness then your fine, the actual harness that runs thought the dash will need to be swapped to a 96-99 obd2a
Old Nov 11, 2007 | 06:41 AM
Comp97GSR's Avatar
Default Re: (94rs-turbo)
From what I have seen, 97's use bigger connectors compared to the 98's. I would stick with only 98 wiring. IMO
Old Nov 11, 2007 | 07:07 AM
importfan2's Avatar
Default Re: (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">From what I have seen, 97's use bigger connectors compared to the 98's. I would stick with only 98 wiring. IMO</TD></TR></TABLE>
thats what im trying to do....plug & play ftw
Old Nov 11, 2007 | 07:32 AM
tartje's Avatar
Default Re: (importfan2)
wow. hell of a good job you're doing bringing her back to life
Old Nov 11, 2007 | 08:08 AM
Hooch'n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">From what I have seen, 97's use bigger connectors compared to the 98's. I would stick with only 98 wiring. IMO</TD></TR></TABLE> Yep. If you arn't running ABS then you should be OK, just make sure you have the right pins for brakes/etc. under the steering wheel
Old Nov 12, 2007 | 08:14 AM
importfan2's Avatar
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">wow. hell of a good job you're doing bringing her back to life </TD></TR></TABLE>
thanks bro.....only 2 years in the making...but she almost done..for now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote"> Yep. If you arn't running ABS then you should be OK, just make sure you have the right pins for brakes/etc. under the steering wheel</TD></TR></TABLE>
everything should be plug & play i hope.... ne one have to repin thier R due to removing abs?
Old Nov 12, 2007 | 03:47 PM
1sikitr's Avatar
gl with tht build
for bringing another R bck 2 life
Old Nov 13, 2007 | 10:50 AM
EG6-DC2's Avatar
Ahmed,
Check with Sohfast, I'm pretty sure they still have a 98 GSR dash harness. Buy that and use that harness. It is pretty much the same thing as the ITR dash harness. Also I wouldn't go and try to make an OBD1 harness work. It won't have the data link connector for the emissions people to hook up to. Trust me, it is a huge pain in the *** to wire it up.
Old Nov 13, 2007 | 11:54 AM
Bradstard's Avatar
My harness was all cut when I got the car. I ended up splicing a GSR harness and using that with the existing ITR harness. It was pretty straight forward to solder the wires since Honda uses the same wire colors on different years.
This is what one my harnesses looked like when I got the car:
After I soldered:
Depending on how many wires you are talking about, it might be quicker to just repair it. It took me a week to fix my harnesses working about an hour each evening after work.
D_koschak
Mar 23, 2016 11:14 PM
shaylude01
Jul 30, 2011 09:47 PM
V/\ freestyle
Mar 13, 2011 08:52 PM
crazy_joe
Audio / Security / Video
Oct 24, 2008 08:53 AM
b.d.racing
Mar 20, 2006 06:17 PM
