fuel rail problem!! need help!!!
Old Nov 10, 2007 | 12:36 PM
killafred187's Avatar
Default fuel rail problem!! need help!!!
my gas is squirting out from where the banjo hose is at and i want to kno how to fix it??
Old Nov 10, 2007 | 12:40 PM
prettylew's Avatar
get new crush washers for the banjo bolt
Old Nov 10, 2007 | 12:45 PM
Default Re: fuel rail problem!! need help!!! (killafred187)
thanks!!!
Old Nov 10, 2007 | 02:04 PM
Tippyman's Avatar
Turn the wrench to the right?
Old Nov 10, 2007 | 02:20 PM
STREETWERKZ's Avatar
Default Re: fuel rail problem!! need help!!! (Tippyman)
we need to ask WHY it is leaking?
did you you recently remove the fuel rail? install new injectors?
sometimes it is simply washers. sometimes people use a pulsation dampener from an EF rail on an EG. the threads are NOT the same. it will cause leaks.
Old Mar 23, 2008 | 12:44 PM
Kr4nG's Avatar
i have the same problem. after installing a new b and m hose fuel is squirting from the rail by the banjo. i tried various of washers and no fix. what is the plastic nut and what does it do anyway. how can i fix this please help me asap. i am willing to do anything to stop this dam leak i dont feel like buying a new fuel rail though cause my motor isnt built for me to use a larger volume. everything is fine by the filter but when i tighten the plastic nut it squirts fuel and my pressure goes down right away. oh and i have a 95 gsr
Old Mar 23, 2008 | 04:39 PM
prettylew's Avatar
Default Re: (Kr4nG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kr4nG &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem. after installing a new b and m hose fuel is squirting from the rail by the banjo. i tried various of washers and no fix. what is the plastic nut and what does it do anyway. how can i fix this please help me asap. i am willing to do anything to stop this dam leak i dont feel like buying a new fuel rail though cause my motor isnt built for me to use a larger volume. everything is fine by the filter but when i tighten the plastic nut it squirts fuel and my pressure goes down right away. oh and i have a 95 gsr</TD></TR></TABLE>
you said you tried various washers? umm were they regular washers? or the special aluminum ones that "crush" to form a seal
make sure u have the proper crush washers in there and also throw some teflon paste on the threads and dont be afraid to tighten it, its not a oil filter. give it a good crank. i mean dont like HULK the thing but definitely make sure its tight
Old Mar 23, 2008 | 06:21 PM
Crx Jimmy's Avatar
Default Re: (prettylew)
they should be aluminum or copper washers, you need 2 of them. one on each side
Old Mar 23, 2008 | 07:06 PM
redsi89's Avatar
Default Re: (Crx Jimmy)
i had the same problem when i put my aem rail on. all i did was buy two copper washers at napa
Old Mar 24, 2008 | 07:28 AM
Kr4nG's Avatar
i bought honda crush washers. the reason it leaks its because of the new hose. ive noticed that the new banjo for the hose is smaller and the stock one is a little fatter. im not messing with it anymore i just put the stock hose on with the stock washers and everything is fine now. it jsut sucks cause i paid 60 bucks for that hose.
Old Aug 11, 2009 | 04:01 PM
LightWeightED8's Avatar
can anyone confirm this about the pulsation dampeners :
1990 CRX Si/HF P/N:16680-PCX-003 or 16680-PE7-661
1994 Civic DX/LX/DX P/N: 16680-PCX-003 or 16680-PE7-661
I looked these up hondapatsdeals.com and 94-95 seem to be the same part number as 90-91 MPFI models. 92-93 models and VX trims dont have a part number available.
94cxhatch
Jul 9, 2010 03:09 PM
Sammyloski
Jun 24, 2009 05:14 PM
eg64u
Aug 16, 2007 05:10 AM
90civSi
Apr 29, 2006 06:45 AM
White86CRXSi
Sep 2, 2004 12:05 PM
