crower cams
Old Nov 10, 2007 | 06:40 AM
dohc_profile's Avatar
Default crower cams
is there a big notice if i were to upgrade my head with crower cams?, and obviously get a good tune.
Old Nov 10, 2007 | 08:30 AM
Schister66's Avatar
Man U FTW
Are you running NA or boosted?? I'm sure there will be a difference, but an LS/VTEC might be a better way to go...
Old Nov 10, 2007 | 08:34 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: crower cams (dohc_profile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc_profile &raquo;</TD></TR><TR><TD CLASS="quote">is there a big notice if i were to upgrade my head with crower cams?, and obviously get a good tune. </TD></TR></TABLE>
Cams, high comp pistons, port+polish and you probably won't get as much out of it as you would doing an LS/VTEC.
Old Nov 10, 2007 | 08:37 AM
AccordSleeperZzZ's Avatar
Default Re: (Schister66)
your setup / future plans for the car / power goals would be helpful information.
there's gonna be a difference, but it also depends on what you already have done to the motor / which cams you're going to get.
if you want to stay NA, unless you get stage 1 cams, you're going to need to bump up your compression to get the most out of your cams. additionally be sho to get 'er tuned.
Old Nov 10, 2007 | 04:48 PM
lickety_britches's Avatar
would crower cams be better than the ITR cams i have now in my GSR?
Old Nov 10, 2007 | 07:34 PM
ls19integra95's Avatar
Default Re: (lickety_britches)
i have stage 2 crower turbo cams, crower dual valve springs, crower titanium retainers, an jg valves... all i got to say is that set up = one noisy *** valve train....
Old Nov 11, 2007 | 08:51 AM
BT207's Avatar
Default Re: (ls19integra95)
You going n/a or are you boosting...
Old Nov 11, 2007 | 09:06 PM
im plannning on N/A setup
Old Nov 12, 2007 | 07:15 AM
mike5809's Avatar
In my NA I had crower 404 cams (their strip cams) full valvetrain and built block of course.
Valve train was very loud, and lacked low end power, needed to adjust the valves quite a bit too. However had amazing mid and top end and I did love the sound of it.
However if i was to go another build i would go turbo instead of NA. Less of a headache and more gains for cheaper cost.
Old Nov 13, 2007 | 08:32 AM
Ls92's Avatar
I have the 404's with the springs and retainers.It has good top end but it sucks on the low end that might have something to do with my intake manifold too.If you go 404's you should increase your compression ratio to get the most out of the cams.
bigbadboy
Jul 26, 2007 07:32 AM
Teg4e
Jul 16, 2003 12:46 PM
ILLA_00LS
Jul 9, 2003 07:22 AM
ASR
Jan 7, 2003 12:20 PM
DLB1994
Aug 4, 2002 12:09 AM
