Recommended spark lpugs for 98 4cyl accord
Old Nov 9, 2007 | 06:05 PM
barker7's Avatar
Default Recommended spark lpugs for 98 4cyl accord
I thought that a search here would turn up some recommendations for plugs - not!
So, any suggestions: for better mileage? for better power?
the car has 115K miles. the wires appear in good shape. Could there be unseen wear, and so they should be replaced anyway. Stock Honda wires the best?
Old Nov 9, 2007 | 06:14 PM
accord99power's Avatar
Default Re: Recommended spark lpugs for 98 4cyl accord (barker7)
NGK Iridium spark plugs is whats stock and make sure you get them again stock wires are fine. inspect the tubes for hot spots.
Old Nov 9, 2007 | 08:10 PM
steerh67's Avatar
stock plugs are just fine, you aren't going to notice any difference in power just by switching plugs. anybody who tells you different has probably fallen victim to the placebo effect
Old Nov 9, 2007 | 08:41 PM
surfer1735's Avatar
denso iridiums work to i got them in my -01 accord
Old Nov 10, 2007 | 04:07 AM
barker7's Avatar
Default Re: Recommended spark lpugs for 98 4cyl accord (steerh67)
What do you mean by "inspect the tubes for hot spots". How do I do this and what causes it? Do i need to pop the valve cover?
Thanks
Old Nov 10, 2007 | 02:14 PM
ZiGeNX77's Avatar
Don't waste your money on those "special" plugs. Go OEM... NGK's.
Old Nov 12, 2007 | 12:24 PM
youll see color distortion on the tube kinda like a bluish color in a certain spots. just a tip.
Old Nov 13, 2007 | 03:56 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Recommended spark lpugs for 98 4cyl accord (accord99power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power &raquo;</TD></TR><TR><TD CLASS="quote">NGK Iridium spark plugs is whats stock and make sure you get them again stock wires are fine. inspect the tubes for hot spots.</TD></TR></TABLE>
wait... since when did Iridium plugs come stock in the Accords?
It should be regular NGK ZFR5F-11, or if you prefer Denso KJ16CR-L11.
Old Nov 13, 2007 | 09:14 AM
doubleecho's Avatar
Denso Iridium are great. They cost about 50 bucks, but since they also burn hotter than stock, so your gonna need some better wires. Go for some Bosch Platinum wire set. They also run about 50 bucks.
Old Nov 13, 2007 | 01:03 PM
defaced8's Avatar
Default Re: Recommended spark lpugs for 98 4cyl accord (doubleecho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubleecho &raquo;</TD></TR><TR><TD CLASS="quote">Denso Iridium are great. They cost about 50 bucks, but since they also burn hotter than stock, so your gonna need some better wires. Go for some Bosch Platinum wire set. They also run about 50 bucks.</TD></TR></TABLE>
Iridium plugs are not OEM Honda. They use just regular NGK copper plugs. Just replace them with those.
There is no need to spend that much money on plugs and wires. The copper NGKs are probably going to run you about $1 a piece and are the best ones to use on a Honda. I've talked to plenty of Honda mechanics who will always say that you do not want to use Iridium or Platinum plugs in any Honda. Do what you want though.
Old Nov 14, 2007 | 11:18 AM
I thought v-power was irdium opps. i just looked it up
OEM part# 98079-5514G S/PLG (ZFR5F-11) 4 1999 ACCORD
V-Power Spark Plug
I wouldnt use the denso wires though oem wires and plugs are good enough, unless you running forced induction.
Old Nov 14, 2007 | 06:28 PM
PnX-R's Avatar
That's a great idea. Go buy those plugs and wire set...
And by the way, remember to tow that car of yours to my dealer and ask for me.. I'll make sure you get a good deal on OEM Honda spark plugs and wires... Maybe a valve adjustment too..
"This is going to be the easiest 3 hours I'll ever make!"
m0squ1t0
Sep 8, 2009 06:00 PM
Honda-Evolution
May 3, 2005 02:59 PM
jdmjeff
12
Nov 20, 2003 01:26 AM
silveraccord01
May 6, 2003 09:03 PM
Saloon-Cruiser
Aug 27, 2002 09:43 PM
