Installing Power Steering ***Opinion***
Old Jun 23, 2002 | 07:06 PM
oxSLEEPERxo's Avatar
Default Installing Power Steering ***Opinion***
I know most of you guys don't like power steering, however, I need my power steering. I'm looking to buying an eg or ek. All the cars that I've looked at don't have power steering and it's making it a freaking hard decision.
It's either get a manual without p/s or get a auto with ps. I enjoy driving manual, but I dunno how much i will enjoy it without p/s.
If i was to get a eg or ek without p/s, is it pretty cheap to get this option?
Thanks for all your help
Old Jun 23, 2002 | 07:20 PM
DigitalFusion's Avatar
Default Re: Installing Power Steering ***Opinion*** (oxSLEEPERxo)
u have to get an entire steering rack if u swap over to power from manual, not to mention the pump, hoses, etc... it would be a huge PITA to swap.
Old Jun 23, 2002 | 07:25 PM
POLLO's Avatar
You will get used to not having power steering, it sounds hard at first but really isn't and is a great excercise.
I have ps on my 99Si and no ps on the VX. And the feel is so weird when im driving the Si, the car just feels twitchy everytime i take a turn.... Is nice when you are parked still and need to turn the steering wheel but when you are moving the feel is the same as if you didn't have any.
Good luck on your decision.
Old Jun 23, 2002 | 07:32 PM
PSU's Avatar
PSU
formerly DxHatchback
when i first got my car, i wasn't old enough to drive it. well my mom let me take it out, and i was like man, this is hard. but after the first day it got easy, and now i love it.
Old Oct 7, 2005 | 03:17 AM
vc's Avatar
vc
Default Re: Installing Power Steering ***Opinion*** (DxHatchback)
I was going to make a new thread about power steering and peoples opinions on it, but since this is made, why not revive it!
So.. I have a 92 civic cx.. and there is no powersteer on it.. I'm used to it and all but I kinda miss the ps.
Pros: Great response, easy to dodge cars while going fast.
Cons: Hard to turn while driving slow and its kind of dangerous when you need to make a fast turn
I want to get it but I heard you lose ~1-5whp, I think thats a rumor because there is no proof that you actually do lose whp(correct me if I'm wrong). No one has dyno'ed with and without ps just to see it, I think you just lose some throttle response.
Lets hear some Pros, Cons and Opinions!
Old Oct 7, 2005 | 03:31 AM
eL's Avatar
eL
no ps esp when driving fast.
Old Oct 7, 2005 | 03:44 AM
vc's Avatar
vc
Default Re: (eL)
Oh, btw my civic is a DailyDriver.
Old Oct 7, 2005 | 04:04 AM
Headshot_Seven's Avatar
Is easy once u get use to it. not worth spending money on it in my opinion
Old Oct 7, 2005 | 04:13 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Installing Power Steering ***Opinion*** (vc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">I want to get it but I heard you lose ~1-5whp, I think thats a rumor because there is no proof that you actually do lose whp(correct me if I'm wrong). No one has dyno'ed with and without ps just to see it, I think you just lose some throttle response.</TD></TR></TABLE>
You need to do more research, because you're seriously spreading misinformation. On one ITR DYNO tested, there was a 7whp difference. Besides the weight difference of losing all the PS-associated crap, that's a VERY significant power difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">Here's what I did:
1. Remove all fluid from system (let pump pump out fluid into a closed container) leaving a little bit to lubricate the system.
2. Remove Pump and cast iron brackets (9.5 lbs)
3. Hook PS line that used to go to pump up to the bottom nipple of the fluid reservoir (sp?).
4. Leave the line that goes to the cooler in the front of the car also hooked to the reservoir.
5. Drive away knowing you are making as much as 7 more whp w/out power steering:
Beyond that, the stock base model Civic manual racks are almost like a power steering rack in their ease of use. An enormous con is that they also have a retardedly large steering rack ratio, so you have to turn the steering wheel A LOT to get a particular amount of actual vehicle turning. The solution to that is an Integra rack, but all 'teg racks ARE PS, and running those without it does have much more turning resistance, and is a bit more added weight (regardless, that's what I've done, and it's totally worth it.).
If the CX manual rack is still "too hard" for you, the better solution to putting PS in is to work your arms out a little and stop being a *****.
Old Oct 7, 2005 | 04:57 AM
monicle's Avatar
Default Re: Installing Power Steering ***Opinion*** (DigitalFusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DigitalFusion &raquo;</TD></TR><TR><TD CLASS="quote">u have to get an entire steering rack if u swap over to power from manual, not to mention the pump, hoses, etc... it would be a huge PITA to swap. </TD></TR></TABLE>
its not that bad. http://repo.jackmoves.com/album119
Old Oct 7, 2005 | 11:55 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Installing Power Steering ***Opinion*** (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">
If the CX manual rack is still "too hard" for you, the better solution to putting PS in is to work your arms out a little and stop being a *****. </TD></TR></TABLE> Agreed, besides the money you would waste could be close to a years membership at a gym.
Old Oct 7, 2005 | 12:16 PM
96CivicBoostCoupe's Avatar
Default Re: Installing Power Steering ***Opinion*** (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote"> Agreed, besides the money you would waste could be close to a years membership at a gym.</TD></TR></TABLE>
NO P/S is much better
Old Oct 7, 2005 | 02:35 PM
vc's Avatar
vc
Thanks for all the comments
Old Oct 7, 2005 | 02:57 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i run p/s on my race car, nothing wrong with it.
Old Oct 7, 2005 | 03:06 PM
Suspetise...
Default Re: Installing Power Steering ***Opinion*** (Rodney)
Don't listen to him. Rodney doesn't need the extra power and DOES need the PS for his scrawny little arms.
Just playin', y0. I bet that does come in handy with those front steamrollers though.
maubee_1
Jul 23, 2008 04:23 AM
dELfONiK
Mar 9, 2007 12:14 PM
sohc_freak
18
May 24, 2006 07:56 PM
hondadriver
Jan 27, 2004 01:31 AM
i HAVEtheADVANtage
Mar 17, 2003 10:32 PM
