2006 Accord Steering Wheel Audio Controls
Hello.. new owner accord 06 lx and first post. The accord I just bought does not have the steering wheel audio controls. Anyone know if it is possible get the controls installed? Can you get the factory buttons and install them in or is it more complicated than that? (eg would you have to put in the wiring, etc.)
I believe only the EX's came with that (Premium Sound System) and probably more trouble than its worth to swap it onto yours (would require running wires/etc as I dont believe they use the same harness)
I've heard of people buying head units with remotes, then taping the remote to the steering wheel.
I would never do it, very tacky in my opinion, but it is an option.
The kit is a $150 item, plus the cost of the radio.
But the radio can be pretty much anything you want and there are some great $150 to $200 head units out there. Do it so that you can get a great head unit and play .mp3s, .aacs, whatever, not so you can tape a remote control to your steering wheel.
Speaking of head units, I picked up a new head unit for my '95 Camry this summer, this head unit has a USB port in front. I just load whatever onto a flash drive and plug it directly into the radio - very convenient. I mainly download podcasts onto the flash drive then listen to them while commuting to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">i dunno if you can transplant an ex radio in there or not........</TD></TR></TABLE>
i dont see why you couldnt...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteBB2 »</TD></TR><TR><TD CLASS="quote">
i dont see why you couldnt...</TD></TR></TABLE>
You CAN, but i've seen similar attempts with nav and audio systems in other cars, and the wiring is such a hassle and you're often without instructions, plus the parts are so expensive. It just ends up not being worth it for most people.
The answer of that will be provided tomorrow I promise.
I have 2006 LX Accord, but the Audio System in it is Premium (Digital Climate Control and 6-in-dash).
On my steering wheel, I have only the Cruise Control, I went to a junk yard today, and brought a full steering wheel without the airbag, but it has both Audio and Cruise controls.
What I intend to do tomorrow is change the whole steering wheel and try!
So, will let you know tomorrow.
Sami
Note: Still need to make the "Outside" temperature on my odometer work, but unfortunately, couldn't find Celsius degrees accessory for it (I live outside USA). Anyone can help?
Sami
It didn't work
I plugged it as it is (Cruise + Audio) into my white female plug under the airbag, and tested it but the radio didn't response!
Looks like there is more connection to be made somewhere.
.I plugged it as it is (Cruise + Audio) into my white female plug under the airbag, and tested it but the radio didn't response!
Hi Again
It did WORK this time:
Just run 2 wire from the back of the Radio to the Audio Control Unit on the wheel, passing by of course the steering wheel "black turning ring" connections.
Hope it will works with you.
Thank you
Zouroub
Thank you
Zouroub
good pm sir i need your help, i also have honda accord 06 lx and add volume control on the steering wheel but it didnt work on my after market radio, you mention 2 wire from the car stereo to the volume control do you have photo or do you remember what connections to be use to work the volume control. And have waiting for your reply
pmilnes
Audio / Security / Video
Mar 24, 2004 02:03 PM
