Degreeing cams...HARD OR EASY!
Old Nov 9, 2007 | 03:52 AM
eg6madness's Avatar
Default Degreeing cams...HARD OR EASY!
how hard is it to degree cams in the first place. If it is easier than building an engine then i can do it since i built my bottom end.
How hard is it to degree cams with the engine in the car?????
I am about to buy some Buddy club spec 4 or skunk2 pro2 cams depending on which will make my B18C with P30 pistons happier. But i wanted to know if i would have to remove the engine or can i do it with motor in the car.
PS i mean with a degree wheel and dial gauge. not by just the cam gears
Old Nov 10, 2007 | 12:10 AM
Aquafina's Avatar
Default Re: Degreeing cams...HARD OR EASY! (eg6madness)
Pretty simple, just time consuming.
Old Nov 10, 2007 | 09:34 AM
eg6madness's Avatar
Default Re: Degreeing cams...HARD OR EASY! (Aquafina)
so it is best that i take the motor out ?
Old Nov 10, 2007 | 01:46 PM
Aquafina's Avatar
You can do it with the engine in the car.
Old Nov 10, 2007 | 04:29 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">You can do it with the engine in the car.</TD></TR></TABLE>
Only if the degree wheel fits in there against the frame rail.
chickenwing
Sep 30, 2008 03:31 PM
98vtec
51
Apr 12, 2006 12:45 AM
AaronJ
12
Feb 13, 2004 10:36 AM
APP95bomexLS
May 30, 2003 09:07 AM
