underhood fuse box diagram for 95 gsr/searced
Old Nov 9, 2007 | 03:23 AM
polishedturd's Avatar
I like PIE
Default underhood fuse box diagram for 95 gsr/searced
i need the underhood fuse box diagram for a 95 gsr. my fan motors wont come on but the relay clicks like its working and i pulled all the fuses and they look good but it would be good to narrow down which fuse to look for. also if i jump the hot wire to the fans directly to the battery they will come on! please help, thanks
Old Nov 9, 2007 | 05:18 AM
u n v kenny's Avatar
Default Re: underhood fuse box diagram for 95 gsr/searced (polishedturd)
Which fan motors? A/C? Or your Radiator?
Old Nov 9, 2007 | 05:24 AM
I like PIE
niether. when i bought the car the fans were jumped to run at the same time but i didnt like the way the wires were run so i disconnected them and pluged the fans back into the factory connectors and jumped the switch that is down by the trany which should give them power to turn on but all that is happening is the relay is clicking! so i think i blew a fuse somewhere but i cant find it?!
Old Nov 9, 2007 | 05:56 AM
Default Re: (polishedturd)
I only have skematics here at work, no diagrams, sorry.
Old Nov 9, 2007 | 06:04 AM
weavertime1's Avatar
Default Re: (u n v kenny)
I am gonna guess the fans were jumped like this because they stopped working, and the previous owner used a quick fix. If the relay is clicking it may not be working. also, just so you know, the underhood fuse box on gsr's will be the same as the underhood fuse box on ls, gs, ad rs models as well. Use one of the other relays to replace the clicking one and see if it changes anything. Also, another note...On a good running acura/honda, it is hard to get the fan to come one under normal use especially this time of the year. Good luck, and if this question is not answered by tonight I will post the diagram.
Modified by weavertime1 at 7:17 AM 11/9/2007
I like PIE
do you have anything that will help me find the fuse that might be blown? the cover for my underhood fuse box doesnt have a layout on it.
Old Nov 9, 2007 | 06:07 AM
I like PIE
Default Re: (weavertime1)
i did switch the relays and still nothing. also i jumped the two fans back together the way the prev owner had them and then tried jumping the swich and still nothing?
Old Nov 9, 2007 | 06:19 AM
If all else fails, pull and examine every fuse. it might take a bit, but thats a sure fire way to find it. Good luck!
Old Nov 9, 2007 | 06:22 AM
I like PIE
lol i tried that too. i think i just need to get and ohm meter and/or test light to figure out whats going on but i still would like to know which fuse is for what???
dc97
Oct 18, 2012 08:38 AM
mark458
May 3, 2010 08:07 AM
trustdestruction
Mar 30, 2009 06:58 PM
staticrex
Jul 25, 2005 12:32 PM
Jays91DXhatch
May 11, 2004 08:06 AM
