valve cover paint
Old Jun 23, 2002 | 05:55 PM
TDRacing's Avatar
Default valve cover paint
I recently stripped my vave cover, because I was going to polish it. Now I have found out how much work is involved in this, and I want to paint it the same color as the type R one. Do any of you guys know where to get that same paint, the same texture and color? I want that ripple paint so it looks stockish thanks
Old Jun 23, 2002 | 06:35 PM
Mr.JaCkeL26's Avatar
Default Re: valve cover paint (TDRacing)
at any hardware store there is a paint that people use to paint their engine block, b/c it can take so much heat. i dont know if it'll make it stockish but it will stay on for sure.
[Modified by GsRHaTch, 11:01 PM 9/24/2002]
Old Jun 23, 2002 | 06:41 PM
Trinity's Avatar
call honda or acura my bad, and ask them. see what they can do for you
Old Jun 23, 2002 | 10:12 PM
spettinger's Avatar
Default Re: valve cover paint (Trinity)
your valve cover should never see more than 200 degrees, so high heat engine paint is fine. i have even heard of some people using "crackle paint" to get the stock look. i would like to look into going that route.
Old Jun 23, 2002 | 10:36 PM
HandCommand's Avatar
Years ago, on my Prelude, I used the Folia Tec Brake Caliper Laquer on my Valve cover. It turned out decent and matched my Calipers. You mind as well do anything you can when you use that kit since its a 2 part laquer with hardener so once mixed its good one time. That stuff is durable and thick. It repels oil, dirt, etc. I see too many people go through the trouble of re-painting their calipers and covers every now and then with cheap hardware high temp paint.
Time is money, I'd rather spend a little more money on the good stuff and only do it once. Plus, it looks 10 times better.
You can view my Prelude engine bay at http://www.hondaprelude.com
Click on Set-ups, 3rd gen Preludes.....name---"Prelusions"
I still have that car. I think it will die with me.....it holds a lot of sentimental value. My early years of Blood, Sweat, and Tears.
Old Jun 23, 2002 | 10:46 PM
Default Re: valve cover paint (HandCommand)
WOW, I havent updated that page for awhile. Pretty much nothing has changed except now I am rolling on some 17 inch Racing Hart C2's and have Alpine Multi-media and Navigation.
There are some good shots of the engine bay (valve cover paint) you can click on.
Here is a link: http://www.hondaprelude.com/setups/s...sply.asp?id=44
Old Jul 1, 2002 | 12:56 PM
justagsr's Avatar
check this thread: https://honda-tech.com/zerothread?id=209663
Old Sep 24, 2002 | 04:59 PM
ragejed's Avatar
Default Re: valve cover paint (justagsr)
lol Valve cover will never see of 200 degreese....I bought 1200 degree paint bahahah
Old Sep 24, 2002 | 05:05 PM
slowman's Avatar
I took way too long
Default Re: valve cover paint (ragejed)
Engine Enamel:Ford Red
Old Sep 24, 2002 | 07:56 PM
ijjz's Avatar
Default Re: valve cover paint (slowman EF)
https://honda-tech.com/zerothread?id=271442
Old Sep 24, 2002 | 09:42 PM
TDRacing's Avatar
Default Re: valve cover paint (ijjz)
this was 3 months ago man. Yeah, i painted mine with crincle paint and that's what it ended up looking like.
Old Sep 24, 2002 | 10:11 PM
KiddieRydesCRX's Avatar
If you want that look, spend the $$$ and get it powder coated
Old Sep 25, 2002 | 06:40 AM
Ham'ed Hatch
Guest
Posts: n/a
oh how special, matching valve cover and calipers!
Old Sep 26, 2002 | 12:48 PM
tpr's Avatar
tpr
Go to your local motorcycle shop and ask for wrinkle paint. It is used to paint the drive cases of motorcycles. The black looks exactly like the Honda valve cover finish. Follow the directions exactly as if you do not you will do it over again. As i recall it costs about $4.95. After it has fully cured use a flat file to remove the paint from the Honda Logo. It will look as good as or better than stock.
TPR
uses0ap
Mar 15, 2006 07:37 PM
xxxmikenicexxx
Apr 30, 2005 11:14 AM
mountaindewguy
Mar 9, 2005 06:37 PM
jsteezy1290
18
May 12, 2004 08:59 PM
vtec-outlaw
Feb 4, 2002 04:53 PM
