a/c with swap
is it possible to have a crx with a b16 swap and retain the a/c? i might be buying one but the seller said there is no room for the a/c. if you can what parts do i need to make the a/c work ie. half size radiator etc. i tried searching but couldn't find what i needed. thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gLUDE »</TD></TR><TR><TD CLASS="quote">somebody has to know.. bump</TD></TR></TABLE>
You can make it work with your stock A/C system, but you'll need HASport's BtoD A/C bracket. (D-series compressor on a B-series engine). It's also easier to work with if you use the stock B16 Exhaust Mani. If you're using an aftermarket header, you'll need a slim fan to replace the A/C fan and possibly custom lines. Check out "Wes V."'s resource page in the FAQ, he's got a writeup about how he did it with an LS swap in a hatch.
Hope that helps.
Hope that helps.
i'm the same install right now...there is also a bracket from innovative that is about 30-50 bucks cheaper...you will need the d-series pulley off the side of the stock bracket. Also the innovative bracket only works with the sanden compressor. I belive hasport has brackets for both. FYI the discharge hose for the sanden and matsushita compressor are different. I bought two at the junkyard before realizing that they're different. I actually have 3..haha. if you need extra hoses, incomplete wiring harnesses, and a matsushita compressor if you need. I forget what I have else I have in my garage. Installing this a/c has been a pain in the @ss. I bought a slim fan for the compressor because there might be a fitment issue with the engine swap. PM me for questions....I've researched just about everything on this install.
all stock lines can be used unless your turbo is in the way...
yea..u can do that..fitment in the front of the condensor might be hard since one of the hardlines goes across the front of it....i think a guy put the fan in the front but to custom build a/c lines.
i'd sacrifice headers for a/c any day on a street driven car..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93dagsr »</TD></TR><TR><TD CLASS="quote"> put them on the outside and reverse polarities so they blow not suck??</TD></TR></TABLE>
Must... resist.... dirty... reply.....
Yes, this is possible as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnerman »</TD></TR><TR><TD CLASS="quote">i'd sacrifice headers for a/c any day on a street driven car..</TD></TR></TABLE>
There is no reason why you can't have A/C with a header. You either have to use a VERY slim condensor fan OR just live with an A/C that can't be used unless the car is moving.
Buy the Hasport bracket!! I know there are cheaper ones out there, but it's the best I've seen. If the alignment isn't correct, you will throw belts.
Here is the link to how I re-installed the AC in my 89 hatchback with B18C (not an LS as Wizco said).
http://www.performanceforum.co....html
How difficult it is varies due to what combination of parts you are using!!!!!
The big thing is that it's possible.
Wes V
Wes V
UnspokenTruth
May 11, 2004 07:01 PM
