resettig ecu after seafoam
Old Nov 8, 2007 | 01:20 PM
Slo_Accord's Avatar
Default resettig ecu after seafoam
i was wndering how you reset your ECU after using Seafoam
Old Nov 8, 2007 | 02:00 PM
Chiovnidca's Avatar
Default Re: resettig ecu after seafoam (Slo_Accord)
Disconnect the battery for about 20 seconds.
Old Nov 8, 2007 | 02:05 PM
Perfectionist's Avatar
Why do you feel it is necessary to reset the ECU?
(BTW, disconnecting the battery will reset the ECU, but cause more trouble than it's worth. Radio code reset, idle speed, etc. There is a better way.)
Old Nov 8, 2007 | 02:08 PM
TheMuffinMan's Avatar
He knows where you live!
ECU Fuse
Let it adjust to the newly cleaned system (if he cleaned the IACV or FITV)
Old Nov 8, 2007 | 02:56 PM
accord99power's Avatar
Default Re: (TheMuffinMan)
dont you do both at the same time batt and fuse? i usually do. is their a difference?
Old Nov 8, 2007 | 02:59 PM
That's overkill
Fuse kills power to ECU
Battery kills power to ECU
one or the other
Old Nov 9, 2007 | 02:06 PM
Slo_Accord's Avatar
Thanks, it was hilarious. the whole driveway was in white smoke
Old Nov 9, 2007 | 02:51 PM
Bruce Banner's Avatar
Default Re: (Slo_Accord)
interesting, never thought of resetting the ECU after seafoam
Old Nov 10, 2007 | 12:47 AM
tpot90's Avatar
Default Re: (Bruce Banner)
I cant find the dam fuse to the ECU. I heard it was labeled "back up fuse" but i didnt find one labeled that. What fuse number is it? Or which fuse box is it found in?
& does resetting the ECU correct or fix any idle problems?
I have mentioned my little idle problem recently and i believe its because of my new SRI & AEM filter.
Sometimes my car boggs out.
Modified by tpot90 at 1:27 PM 11/10/2007
tbuck23
Apr 1, 2007 05:50 PM
OpTiX619
May 14, 2005 10:05 PM
d8168055
Mar 26, 2003 01:54 AM
WheAs MaI MojO
Jan 30, 2003 07:49 PM
cp_harrington
Jan 20, 2003 08:35 PM
