cleaning exhaust ports
Old Nov 8, 2007 | 12:58 PM
92civicx's Avatar
Default cleaning exhaust ports
ok so my exhaust ports have a good amount of idk buildup and it seems to have harden. I've searched and couldn't find anything.
Has anyone done this before? any tips on how to get this stuff out?
i'll be updating showing what i mean by "buildup" with pics.
Old Nov 8, 2007 | 04:43 PM
Projekt_2nr's Avatar
Default Re: cleaning exhaust ports (92civicx)
seafoam your motor, find some local shop that'll do it for you, its the easiest way of doing it, it'll eliminate all carbon build up on the pistons ports and whole exhaust, your motor will run excellent afterwards, i believe it costs $35 if i remeber right but i9t may cost more around your area
Old Nov 8, 2007 | 06:29 PM
92civicx's Avatar
Default Re: cleaning exhaust ports (Projekt_2nr)
cool so just get some seafoam and it should be good? thnx for the tip
Old Jan 11, 2008 | 06:38 PM
92civicx's Avatar
i dont' want to start another thread.
I did some research on seafoam it seems to work good for some people and other people not good at all.
so what are my other options? Would i be able to use some carb cleaner and a brush?
Old Jan 15, 2008 | 09:03 PM
DC4R27's Avatar
bump i want to know also
Old Jan 16, 2008 | 11:41 AM
92civicx's Avatar
Default Re: cleaning exhaust ports (DC4R27)
bump
Old Jan 16, 2008 | 01:00 PM
92civicx's Avatar
also if i can do it that way and the carb goes inside the head above the valves, can this cause any harm?
Old Jan 21, 2008 | 05:12 PM
92civicx's Avatar
https://honda-tech.com/zero...00666
Old Jan 21, 2008 | 08:35 PM
i-Touge Eg6's Avatar
dont use a wire brush unless your gonna dis assemble it to clean, last thing you want is a brissle to fall threw your valves. other than that use carb cleaner and a wrag. itll take some rubbin and lovin
the carb cleaner will just burn on the power stroke, aint nothin to worrie about
Old Jan 26, 2008 | 01:59 PM
Legion's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Projekt_2nr &raquo;</TD></TR><TR><TD CLASS="quote">seafoam your motor, find some local shop that'll do it for you, its the easiest way of doing it, it'll eliminate all carbon build up on the pistons ports and whole exhaust</TD></TR></TABLE>
Lol, seafoam won't do ****
Old Jan 26, 2008 | 02:03 PM
Legion's Avatar
* B A N N E D *
Default Re: cleaning exhaust ports (Legion)
I always have vast amounts of buildup on my pistons/ports. The only way to get it off is with a wire brush and a flat-head screwdriver to chisel off the larger chunks. I've tried dozens of solvents, but nothing really works. Brakleen helps, but it goes fast so you'll need a few cans of it.
Old Jan 26, 2008 | 04:24 PM
92civicx's Avatar
yeah carb cleaner and wrag didn't work so i needed either to chisel it or wire brush. i chose brush but now i have some of the buildup on top of the valve .
the only way i would do this again is if its dissembled.
Old Jan 26, 2008 | 05:49 PM
Legion's Avatar
* B A N N E D *
I've had good luck with a die grinder and a paint stripping wheel for the valve faces. It removes the carbon in an instant.
EDIT: Here's what I'm talking about. You can get this little kit at Home Depot for about $10. The greenish looking wheel is like brillo pad material and it works great. Just don't overdo it or you'll scratch up the valves. And if you don't have a die grinder, you can use it with an electric drill, it'll just take longer.
Old Jan 26, 2008 | 08:18 PM
Coal_forge's Avatar
I did mine with brake cleaner and it did fine for me. It came off in chunks/flakes.
If you spray it in there make sure you take the spark plugs out and turn the engine with the starter to blow out any fluid build up in the cylinder.
Other ideas:
Would to be to use an abrasive blast of dry ice pellets.
Use a blow torch to heat up the carbon very slightly it and then spray the solvent on it to crack it. Try not to heat it where the metal is hot to the touch now do not want to cause cracking of the head.
Old Jan 29, 2008 | 11:10 AM
Default Re: cleaning exhaust ports (Coal_forge)
did you just sayin use heat then ice on a aluminum head? dont use a chisel
wire brush, lots of carb cleaner,period. make shure you blow the ports out, if you end up with busted rings youll know why.
you know the ports you cleanin are gonna be black again on the first day you drive dont you?
Old Jan 29, 2008 | 01:23 PM
92civicx's Avatar
Default Re: cleaning exhaust ports (i-Touge Eg6)
after i was done i started it and let it burn out all the carb that went inside.
next time maybe a different technique....
Modified by 92civicx at 7:40 PM 1/30/2008
b20turbojason
Welding / Fabrication
Aug 28, 2008 09:07 PM
92civicx
Jan 21, 2008 05:08 PM
OrangeBoost
Oct 14, 2007 03:07 AM
TypeRKoncepts
Dec 21, 2004 03:44 PM
Jeager521
Nov 10, 2002 01:55 PM
