Chipped Crank Pulley to replace Unorthodox one
Old Nov 8, 2007 | 12:18 PM
silverlude80's Avatar
Default Chipped Crank Pulley to replace Unorthodox one
I purchased a used stock crank pulley that was damaged in the mail. there are multiple chips on it and I'm wondering if this will effect anything in any way. I hear this is balanced and dampered, and could cause lots of damage using aftermarket parts ie.. unorthodox pulley. That is why I am changing it in the first place. I don't want to replace a bad part with another bad part.
2000 base prelude if thats important
Thanks
Old Nov 8, 2007 | 01:33 PM
Padawan's Avatar
Darth ModerVader
Default Re: Chipped Crank Pulley to replace Unorthodox one (silverlude80)
There's nothing wrong with running the UR pulley, but if you want to install the stock one, I'd have it rebalanced first.
Old Nov 8, 2007 | 01:55 PM
eg6_itb's Avatar
CTR N1 CRANK PULLEY......
Old Nov 8, 2007 | 05:51 PM
Bjorn20's Avatar
I would honestly just stick with oem. Even if your heavily modifing the engine, i still doubt you would even notice a gain from going with lighter pullies. I dunno i just dont think its worth it.
If the crack isnt bad, doesnt interfear with your timing marks or belt, i wouldnt be worried about it.
Old Nov 8, 2007 | 06:05 PM
Default Re: Chipped Crank Pulley to replace Unorthodox one (Bjorn20)
The chips are pretty bad, I would feel safer just buying a new one from honda
Old Nov 8, 2007 | 10:03 PM
Richard...'s Avatar
Default Re: Chipped Crank Pulley to replace Unorthodox one (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">There's nothing wrong with running the UR pulley</TD></TR></TABLE>
http://www.unorthodoxracing.com/faq_pulleys.html
read this
Old Nov 9, 2007 | 08:04 AM
Default Re: Chipped Crank Pulley to replace Unorthodox one (Richard...)
Yes, I have read that already, but how can you trust a company that is talking about their own product? If it was a third party that did some testing or something I would buy it. This is more for my piece of mind, why risk it with all the controversy behind it? I hear a lot of people say its okay to put the chipped one on also, but I hear people saying the opposite too. I'd rather go with a new one than put a damaged part on. Whats the point of replacing an iffy part with another iffy part?
Thanks
Old Nov 9, 2007 | 01:26 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude80 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I have read that already, but how can you trust a company that is talking about their own product? If it was a third party that did some testing or something I would buy it. This is more for my piece of mind, why risk it with all the controversy behind it? I hear a lot of people say its okay to put the chipped one on also, but I hear people saying the opposite too. I'd rather go with a new one than put a damaged part on. Whats the point of replacing an iffy part with another iffy part?
Thanks</TD></TR></TABLE>
LOL
when i saw honda made this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6_itb &raquo;</TD></TR><TR><TD CLASS="quote">CTR N1 CRANK PULLEY...... </TD></TR></TABLE>
was all the proof i needed i do not claim to know more then honda on anything to do with engines or cars...
Old Nov 10, 2007 | 04:37 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Richard... &raquo;</TD></TR><TR><TD CLASS="quote">
read this </TD></TR></TABLE>
Yes....because the seller of the product always posts unbiased opinions on that matter at hand.
WRONG. That page is so full of BS I can e-smell it. Do your own research
To the OP, like I said in the other thread: The chips on the outside of the pulley do not effect the balancing of the bottom end, as Honda engines are internally balanced. Furthermore, the harmonic dampener (rubber ring) on the OEM pulley isolates the harmonics in the crankshaft's system from the outer part of the crank pulley.
The only way I would worry about a chip out there is if it was either detrimental to the pulley/belt system or was so massive that the vibrations caused by it were large enough to visually "wobble" due to overcoming the rigidity of the rubber ring.
What I would do here: Replace the pulley with a new OEM unit.
Old Nov 10, 2007 | 05:10 PM
Richard...'s Avatar
Default Re: Chipped Crank Pulley to replace Unorthodox one (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
What I would do here: Replace the pulley with a new OEM unit.</TD></TR></TABLE>
bro the R&D has been done the N1 honda made thats all the proof i need...
mrowxlived
Sep 9, 2017 10:54 AM
silverlude80
Apr 9, 2008 11:03 AM
j_wod2000
Mar 2, 2006 02:17 PM
mahatma
41
Nov 8, 2005 08:17 PM
rolow
Jan 20, 2005 12:48 PM
