AWD Honda
Old Nov 8, 2007 | 10:33 AM
ickyhonda's Avatar
Default Another AWD honda
Starting this thread midway through the build of my AWD civic.
Here is one of the rear arms and was so far the most difficult portion of the build.
With the hub and painted.
Modified by ickyhonda at 1:05 PM 11/8/2007
Modified by ickyhonda at 9:49 AM 11/9/2007
Old Nov 8, 2007 | 10:46 AM
TunerN00b's Avatar
Default Re: Another AWD honda (ickyhonda)
I'm just curious here, but why does everyone converting either an Integra or Civic to AWD, cut and weld the trailing arms?
EG and DC trailing arms are the same, and the Integra XSi was available as RT-AWD. I would think just using the XSi trailing arms and rear subframe, would be all that necessary to mount the diff and axles back there.
Old Nov 8, 2007 | 11:15 AM
purplecivicturbo's Avatar
Default Re: Another AWD honda (TunerN00b)
I once asked about the integras, i was told they didnt do it.. But i do know for sure there was an EG shape, RTSi with the RT4WD system, but the parts and cars are rare- and i mean rare...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">I'm just curious here, but why does everyone converting either an Integra or Civic to AWD, cut and weld the trailing arms?
EG and DC trailing arms are the same, and the Integra XSi was available as RT-AWD. I would think just using the XSi trailing arms and rear subframe, would be all that necessary to mount the diff and axles back there.</TD></TR></TABLE>
Old Nov 8, 2007 | 12:33 PM
suicide_shift's Avatar
* B A N N E D *
becuase 4wd civic wagons are common.....and integra xsi's were never over here......and instead of spending weeks online looking for one.....since we already know how to weld/fab its sooooo much eeaiser to just run a few beads
Old Nov 8, 2007 | 12:56 PM
ickyhonda's Avatar
Default Re: Another AWD honda (suicide_shift)
I could not find junked awd civics all my parts are off a crv, Plus i have a b16 for it and i wanted everything from the same car. Even the shifter... I will post a pick of it soon; promis it will make you laugh.
Old Nov 9, 2007 | 07:56 AM
ickyhonda's Avatar
Here is the CRV shifter mounted. When I sit in the driver seat with my hand on the shifter it fells like i driving a muscle car... Maybe i should get a Hurst shiftknob.
LS integra nuckles with type-r hubs and bearings.
A teaser of the internals on the B16.
Old Nov 9, 2007 | 11:29 AM
ickyhonda's Avatar
Here is a picture of the tranny mount, It was my first expieriance with the acetylene torch. I am going to eventially trim it up or start from scratch.
Here is The Hole. I am mounting the rear diff tonight.
Here is the motor that I had built by PFI Speed in Ft Collins, CO. when i got it running it sounded like crap so I ended up taking it apart after 3000 miles. I found multiple problems. The two main problems were metal shavings and dirt imbedded in my bearings and a piston installed backwards so there was no clearance on the intake valves. Needless to say, I have rebuilt it myself since then.
Modified by ickyhonda at 1:42 PM 11/9/2007
Old Nov 9, 2007 | 01:10 PM
spectacle's Avatar
looks good so far. keep the updates coming...
Old Nov 9, 2007 | 09:36 PM
VRD^don's Avatar
Default Re: Another AWD honda (spectacle)
should be a cool build! GL on the build!
Old Nov 11, 2007 | 05:27 AM
gibsanez's Avatar
Default Re: Another AWD honda (VRD^don)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ickyhonda &raquo;</TD></TR><TR><TD CLASS="quote">and a piston installed backwards</TD></TR></TABLE>
Sounds like a good shop.
Old Nov 18, 2007 | 06:38 PM
92civicx's Avatar
Default Re: Another AWD honda (gibsanez)
any updates
Old Nov 29, 2007 | 03:17 PM
ickyhonda's Avatar
Default Re: Another AWD honda (92civicx)
Sorry for not posting in awhile. My dad died on the 17th so the car got put on that back burner.
Here is a pic of the rear diff from under the car.
Pick from the top.
Type R rotor VS. Stock VX rotor.
93 Accord Wagovan caliper VS. Civic caliper.
Accord Wagovan VS. Civic brake pads.
That is all you need to do for poor mans big breaks. If you dont have 5 lug you can also redrill the rotors to 4 lug. You also need to have Civic EX with ABS or any 94 and up Integra knuckels. I also forgot to take pictures of the inside of the crv diff. I removed the cluchpak and welded the input shaft for a 50/50 torque split and welded the rear diff to help get the car to rotate. I wanted a lsd but no one makes one for the rear. Only Phantom Grip makes a psudo-LSD for the front diff.
Old Nov 29, 2007 | 04:48 PM
kiddcarbuff's Avatar
wow nice build so u used the integra knckle and presse the type r hub and wheel bearing in it and used the R rotor and caliper? nifty, poor mans 5 lug setup/
Old Nov 29, 2007 | 11:11 PM
juscallmetoad's Avatar
nice project.
Old Nov 30, 2007 | 04:33 AM
basitun's Avatar
Quote, originally posted by TunerN00b »
Reading your post I can say that I am 99% sure that the shuttle trailing arms will fit direcly in 4th gen sedan I guess ... , so I will be happy to see one 4WD sedan that is not stock ... I guess that this will be easy conversion ...
Old Nov 30, 2007 | 12:21 PM
dc2go's Avatar
kick *** project
Old Dec 1, 2007 | 06:39 AM
dtapia's Avatar
Default Re: (dc2go)
sorry to hear about your dad.
nice project.
Old Dec 1, 2007 | 06:56 AM
f@sth@tch89's Avatar
Default Re: (dtapia)
in for updates
this project looks goods. sorry to hear about your dad, keep your head up.
Old Dec 1, 2007 | 03:03 PM
X2BOARD's Avatar
SOrry to hear...May your dad RIP .
Nice project... love the rear bracing.
How will the rear diff hold up to the increased power of a built b16 ?
Old Dec 5, 2007 | 12:20 PM
ickyhonda's Avatar
Default Re: (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">How will the rear diff hold up to the increased power of a built b16 ?</TD></TR></TABLE>
I hope it holds. I dont think it will break too often. The rear end of the braile auto's drift Integra was set up the same way and he had a supercharged B18c. I think he had 280 hp going to just the rear wheels. My center diff if welded so it should have a 50/50 torque split so hopefully it can handle 550 hp (275 front/ 275rear).
Old Dec 6, 2007 | 07:49 AM
b18LS's Avatar
Default Re: (ickyhonda)
Youve got skills my friend, keep it up. Please post again once its on the road!!!
Old Dec 11, 2007 | 08:05 PM
ickyhonda's Avatar
Default Re: (b18LS)
The crv starter fit the transmission but it hit the block so I had to remove some metal from the starter.
Here is the rods and pistons for my buddies ride.
He had to regrind the crank to the gsr rod size to get more flesh on the rods.
Starting to assemble the block.
The darton sleves.
And what I have been waiting for over a month to recieve for my car.
Old Dec 11, 2007 | 10:32 PM
quicksilver1689's Avatar
i ♥ snails
those look like childs albert rods
one of the best damn rods ever made IMO
Old Dec 12, 2007 | 06:44 AM
ickyhonda's Avatar
Default Re: (quicksilver1689)
They were made by GRP (local shop for us), they are essentially the same rods that are in Eggums Civic but made for his K24. They have the same rod journal size as the gsr but longer in length. Even with the huge stroke of the K24 crank these rods are still good up to 9500 rpm and 1200hp. These are great rods, just dont use them if your car is going to touch public roads; they have only a short lifespan.
Old Dec 12, 2007 | 10:37 AM
ickyhonda's Avatar
I need help! Is there any one that knows of a company that makes a LSD for the front diff on the CRV tranny besides Phantom grip. I was thinking that the stock CRV diff has to be the same as a different more popular honda application. Any knowledge on this would be much apriciated.
